James Scott : ur absolutely right, so all i have to do is get the car laser tracked and it will solve the prob?
another prob is that there is a knocking sound when i am turning, is that the axles? |
I'm sure there will be more to what I said... added from much more knowledgeable members...
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . |
Mitch is right Carlito.
You have a busted CV joint on one or both sides. Get this fixed pronto. Phils offer is a good price. Pity your mechanic did not put the car on the ramp and check for damaged joints / loose axels, that would be the obvious way, and would only take 5 minutes. You need to do this to see which CV is broken. Maybe the left and right are the same [Phil??], but in most cars they are unequal lengths, so are not interchangeable. Joe
yea i saw phil's offer and it sounded pretty good..
so the cv joint and the axles are the same thing? |
i juss changed the ball joints and now i have no $, are there any dangers if i drive the car in this condition for a little while?
Carlito
The axle is the thing which carries the power from the transmission or rear differential to the wheels. The CV [constant velocity] joint is the part that allows the front axle to bend as the steering points the wheels in the right or left direction. If the CV joint is making noise while turning, it means that there is wear inside it [it is made fom balls and cups] and it will disintegrate. I drove front drive cars for thousands of miles with clunky CVs. If money is a problem, and you want it to last, NEVER put power on while on lock, only while driving straight ahead. It could last a long time being careful about this. You need also to ensure there is lubrication in the joint. They usually fail because the rubber boot [expandable gasket] has broken and the special grease has escaped. Should it totally break, the axle will fall down, the engine will spin that axle and ignore the other three, and you will be stranded, be it Death Valley or 42nd Street. Get the money and fix it soon Dude. Joe
ok..i finally took it to a different mechanic and he says it's not the cv joints but it's the front struts....
anyone know where i can purchase front struts and links? i am also gonna change my rotors as they appear to be warped, this is indicated when i brake and there is some vibration.. i did the allignment and the car is no longer pulling.. i also have to change the tires as they are worn from the misallignment, previous owner must have hit a curb.. can anyone gimme some online vendors for struts for the svx? thx |
http://www.subaruparts.com/diag/?mod...category=210-A You also might try Liberty Subaru in New York Liberty Subaru 1-888-782-9493 66 Kinderkamack Rd Oradell,NJ 07649 According to the member who posted this info: "Ask for Russ tell then that you saw the advertisement in a car magazine and you'll get 10 to 20% off."
These are just normal struts, any one know any stores selling performance struts? I emailed motorsports warehouse and Dayle said that they are sold out...
Chris G 92 Pearlie, sold @ ~209k miles. Now owned by Tim. Current Ride, 1985 Honda Aero 80, stock 3024 klms |
check the FOR SALE Threads, lots of parts cars with strutts, but a pair of new strutts is always best.
Also, unless you want even a firmer ride, I would stick with stock strutts.
Thread Tools | |
Display Modes | |
