Old 03-06-2003, 04:58 PM
CARLiTO_
I know i post alot but this is important...
My svx pulls to the right like to drive straight, the wheel has to tilt a tiny bit to the right..why is this?
And also there's this knocking sound coming from the font left (driver's side) like a rock fell.....it happens when i press the accelerator and then release..?
Old 03-07-2003, 04:09 AM
Carlito
Pull to the right generally means you have to get the car tracked. It might also mean one or two tyres were below pressure, but they would need to be nearly flat to exert a discernable pull. Get the car 4-wheel laser tracked.
The guy at the tracking centre should also be able to centre your steering wheel, unless something more serious is wrong, like a damaged track rod or ball joint.
Knocking sound could also be damaged suspension joints, or possibly front axle CV joint about to break. Get the tracking done straight away by a skilled shop, then see if the knocking is related to it. Mention the rattle/knock to the tracking technician, because tracking will be a waste of money if you need to replace a damaged/broken joint first.
Best of luck
Old 03-07-2003, 08:18 AM
JLittell
CARLiTO_, No one can post too much on this website. That's what it's here for!!
Old 03-07-2003, 08:39 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Gee, thanks! Now, will you tell people to get off my back?
Meanwhile, back at the subject, Carlito, sounds like Joe's got this one sussed. You may also check for a busted strut mount, causing the knock.
Also, sometimes people complain of "pulling" when the car is actually, simply following the domed surface of the road. Roads/Streets are domed for drainage. Some have more of an arch than others, leading to (what seems to be) pulling to the right.
Anyhoo, have all your steering and suspension components checked out. Therein (more than likely) lies your problem.
Randy Johnson
Mike Davis -- at Reading VI
Old 03-07-2003, 10:41 AM
svx_commuter's Avatar
Ah ? Mr. Johnson did not start this thread?
Is he to be a contender for Randy?
Lets hear it for CARLiTO_.
Old 03-07-2003, 12:52 PM
CARLiTO_
i juss took to to a mechanic and he test drive it, he said it could either be the allignment or rackenpenion (think that's how it's spelt) which has something to do with the steering. The knocking noise is probably something with the suspension, he didnt put the car on the hoist tho, that's juss his hypothesis..
Old 03-07-2003, 01:19 PM
Aredubjay's Avatar
Rackenpenion is the German spelling. In the U.S. it's Rack and Pinion. I certainly hope that's NOT your problem.
Randy Johnson
Old 03-07-2003, 04:59 PM
CARLiTO_
why?
is it expensive to fix?
Old 03-07-2003, 06:02 PM
Subafreak's Avatar
Superbeast
It's an SVX isn't it?
Old 03-07-2003, 09:51 PM
CARLiTO_
is the rack and pinion of the legacy or the imprezza same as the svx?
Old 03-07-2003, 10:04 PM
I don't think so as I don't think they have speed sensitive steering.
Someone correct me if I am wrong.
Old 03-08-2003, 12:28 PM
Subafreak's Avatar
Superbeast
No. Unfortunatly the SVX dosn't share much with the Legacy or Imprezza. Except for the tranny and rear end.
Old 03-08-2003, 12:45 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Wait so the pulling to the side in grooved roads is normal?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-08-2003, 07:47 PM
The Molinator
PULLING?
Sounds like the car's not pulling to the right, but the steering wheel has to be turned to the right for the car to go straight. If I understand correctly, then the steering wheel just needs to be centered (tie rod ends adjusted in or out on each side to center position of wheel when going straight). Great idea to do 4 wheel alignment as suggested, tho!
Jim
Old 03-08-2003, 09:29 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
I have TWo good front axels im selling for 110+ shipping, if you end up needing them just pm me and they're yours!
phil
~Phil
