Old 03-04-2003, 01:55 PM
Mr. Pockets's Avatar
Moderator
Digital ATF gauge
This is specifically for those of you who have Nordskog digital ATF gauges in your cars.
I want to do an installation like this in my car:
http://www.geocities.com/maldbnsf/trannytemp.html
But I want to put mine where the coin box is now. I want to cut out the back of the coin box and just leave the outer part as a bezel for the gauge.
Have any of you taken the gauge apart? Is it constructed like the one in the above photos?
I would just buy the Cyberdyne gauge in the example, but I want the green readout because it'll match the car's displays better.
Oh, and I need to know what temperature sending unit you guys bought to work with this gauge.
Thanks!
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 03-04-2003, 03:59 PM
I've never heard of them before. I have the Dakota Digital gauge with it's own sending unit designed for it.
I'm also thinking of replacing the coin holder with it eventually as well.
Old 03-04-2003, 04:01 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I was thinking more along the line of mounting it in the instrument cluster.
Old 03-04-2003, 07:49 PM
kuoh kuoh is offline
I've thought about replacing the door or trunk indicators with a good digital gauge. If I can just find a good digital display that's small enough.
KuoH
Old 03-05-2003, 08:18 AM
Moderator
I've thought about that, but I'd like my installation to be easily removable. I might even just install connectors so I can pop the gauge out and replace it with the coin box whenever I want. I'm also concerned that the temp gauge will be too big and too bright and overpower the display.
Where I want to mount it, the gauge won't be exactly in my line of sight, which I like. It's not something I want to be constantly aware of, just check once in awhile.
2005 Outback
END OF LINE
Old 03-05-2003, 08:43 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Norskog gauge
Hey Mr Pockets I have a Nordskog gauge in my svx. I didn't install it but got it and took it in. I did take it apart though to examine it and I don't think you'd be able to square it up like that easily. I got mine from Summit and got the standard sender for it and it works fine. Mine is mounted between the instrument cluster and the d. side mirror. I kind of like it there but it does kinda get a reflection sometimes at night. It is quite close to the green of the other stuff though.
Old 03-05-2003, 10:22 AM
Moderator
Re: Norskog gauge
Thanks, Bob.
I don't really want to 'square it up.' And, if I have to, I'll use some scrap plastic to adapt the gauge to the bezel I'll make.
I don't want to install the gauge in an obvious place - I'd rather it was hidden away. I'm just that much of a purist.
Thanks, though. Despite your advice, I'll probably still buy one and try it my way anyway.
2005 Outback
END OF LINE
Old 03-05-2003, 10:40 AM
benebob's Avatar
gauge
I know what you mean. I put mine there so all that I need to do is feed the wires back and it'll look like it was never there. The gauge is a little on the light side if sunlight is on it but not so bright that at night it kills your eyes. The only option I wish it had was a setable flash so when it reached x degrees it would flash.
