Old 03-03-2003, 07:18 PM
alacrity024
ha ha! oh sh|t!
Beav-
I was gonna PM this to you, but I think I should probably let everyone here know how grateful I am. You probably didn't save my life, but you certianly saved me the money I would have spent replacing a bent hub and broken arm when my vehicle came crashing down on me. I was planning to go to my house tomorrow evening to try again, but I'll be heading there tonight to make sure that nothing happens to the car while I'm not there (knock on wood) (not the table that the turntable is sitting on with a record going over the air) (damnit, i made it skip.. oh well, better that i got a good knock in). A million thank yous. Without the people on this board I would have spent a lot more money on my car, and I would probably be missing some fingers
-adam
Old 03-03-2003, 08:18 PM
mbtoloczko's Avatar
sans SVX
Originally posted by alacrity024
where'd you score the splitter? auto parts store or what?
-adam
Yep. Local auto parts store. It wasn't very good quality (the splitter). Sears might have one. Might be more expensive, but it would have a lifetime guarantee.
BTW, I hope you relocated the jackstand as Beav pointed out. You're lucky you didn't get hurt trying to get those bolts out.
Mychailo
Visit my locker
Old 03-03-2003, 09:28 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
I have uploaded few more of my mechanical pictures, including a few that show what you are doing, only my bad axle was the right side.
There is a high res pic(900kb) of the split ball joint, done with a pickle fork, and the bolt that retains the ball joint was removed from the hub first. no other bolts were removed to get the axle out, other than the axle bolt under the wheel, and the center CV knuckle pin was also tapped out, sorry, no picture of that.
mechanical pics link
there are a few other that my help, but the ball joint, and the expossed bearing at around 900kb each.
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 03-04-2003, 12:04 PM
alacrity024
alright, i managed to get the axle out last night. i feel like a "compleat" idiot for having the car supported by the suspension arm, but now i know better.
in order to remove the two bolts from the lower arm, i found it necessary to crank the steering wheel all the way to the left and then all the way to the right. i didn't need to remove the sway bar at all, and the axle came right out.
hopefully it'll go back in with minimal fuss, but we'll see. thanks again everyone who helped
-adam
Old 03-04-2003, 12:41 PM
strange179 strange179 is offline
Still a member
Send a message via ICQ to strange179 Send a message via AIM to strange179 Send a message via Yahoo to strange179
if you need any help
Adam (and anyone else),
I can take pictures of bits and pieces for you if you end up needing help with anything. I'm very familliar with the CV axle procedure so I'd be able to mark up the pictures and make notes for you too. Just thought I'd offer my help to anyone who is having mech issues.
Gotta love this NH winter.
Justin
Speed Safely
Subaru, All We'll Drive
Black '92 LSl 270Kmi 5MT (W00t! for 1/4 million on 4/27/07)
Laguna Blue '94 L about 130Kmi (I think) for parts, in storage
previous: Green '92 LSl 253Kmi 5MT (sold to ron post moose adventure, sold to someone else)
previous: Maroon '92 LSl 130Kmi +- (sold to Ron, mashed by moose, crushed)
Black '89 XT6 5spd AWD (storage)
Old 04-17-2003, 11:03 AM
Re: if you need any help
Justin
i plan on doing the axles asap if you could post up the pics and mark them up that would be amazing...thank you in advance
Old 04-22-2003, 02:38 PM
Still a member
pics
I'll see what I can do for ya. I just found out over the past weekend that my green SVX needs head gaskets. I'll be putting a lot of effort into that in the comming days but I'll try to get it all done up for ya.
Jay
Speed Safely
