Old 02-28-2003, 05:15 PM
DNSB
What Is This For??????
The previous owner of my SVX told me it was a 'switch' for the window's. Everyone that I have talked to said it wasn't. So...Tell me, What is it, and where to put it????
~Deja~
Old 02-28-2003, 05:37 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Those look like the snap ins for the side panels of your interior. I remember seeing clips that look like that when i took off my rear inner panels.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-28-2003, 07:37 PM
DNSB
Well, my passenger side window won't roll up or down from that door. So I took off the window switch thingy, were you see the little bottons that make the window work. If I push on those real hard, I can roll it down, but not up. So... Whats wrong with my window? And does that part fix the problem, or has it another function?
~Deja~
Old 02-28-2003, 07:55 PM
Tim's Avatar
Tim Tim is offline
It sounds like the motor is functioning, you probably need to clean your switches with some rubbing alcohol and letting it dry. Check your switch with a multimeter to make sure theres power going through it. But if you need to push hard for it to work it sounds like a sticky switch
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-28-2003, 07:57 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
I should have the how-to in my locker. If not, I'll re-do it again. But give me another weekend. I am going to be partying this weekend.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 02-28-2003, 08:16 PM
DNSB
Do I have to take the door panel off to do this?
I will try to figure it all out.
Thank you for your reply!
~Deja~
Old 02-28-2003, 09:09 PM
Seraph's Avatar
~Deja~
There are total of 5 screws and a ton of clips for the door. Just in case... if you don't find 5 screws, keep looking. They are there. Just don't want you to rip the door.
L
Current SVX: NONE
Old 02-28-2003, 11:22 PM
Rosevineboy
Post Thingy
The plastic part you show appears to be from a door panel. These little gizmos fit inside the door panel between the first and second lip. The protuding portion snaps into a hole in the metal door skin. There are seven of these for each door. Good luck with your project.
