View Poll Results: what have u replaced
rear wheel bearings 30 42.86%
automatic transmsion 44 62.86%
frount engine or rear main engine seal 12 17.14%
valve cover gaskets 20 28.57%
complete engine over haul 2 2.86%
cv joints 18 25.71%
t.ps sensor 8 11.43%
starter 3 4.29%
alternator 16 22.86%
p.s pump or power steering rack 16 22.86%
engine motor mounts 2 2.86%
suspension work i.e shocks// springs ///bushings 17 24.29%
other 15 21.43%
Brake Rotors 27 38.57%
Multiple Choice Poll. Voters: 70. You may not vote on this poll
Old 01-30-2003, 08:58 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
Question the most common svx problems. poll
im curous what u have replaced on your svx. this is for every one so we wil know exactly what break the most.
i think i got all them covered if there is something else. the moderators can change it.
i think this would help every one in some way
u can choose more then one
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 01-30-2003, 09:10 AM
MNYPNNY's Avatar
MNYPNNY MNYPNNY is offline
FKA....thndrmtn92svx
Alcyone Silver Contributor
Send a message via AIM to MNYPNNY Send a message via Yahoo to MNYPNNY
You forgot brake rotors.....
~~Michelle
~~Michelle
'92 LS-L - copper - 190K miles
'94 LS-L - pearlie - 92K miles
*still have '92 parts*
Old 01-30-2003, 09:11 AM
kuoh kuoh is offline
I don't know if it's possible, but you should add "replaced how many times" for some of the items that we know have repeated failures, like the bearings and tranny.
KuoH
Old 01-30-2003, 09:14 AM
yea good pointe forgot the rotors =>
there isnt a option for how many times,, trying to find out the most common i guess..
i cant change the polls =< only moderators can,, ohhh moderators !!!!!!! we need rotors in there
Mr. Pockets's Avatar
Moderator
~~Michelle
Brake rotors, to me, are consumables - as are many items on solar's list. While it's well-intentioned, I think that this poll lacks the definition it requires to gather any useful information. Many of us are well past 100k miles on our SVXs, and a couple of us are past 200k. After 100k miles, I think that most repairs on the above list are forgivable. Some are not, and the SVX's common transmission failure is an example. The poll also lacks the ability to enter how many times we've replaced each item, as well as the number of miles on our cars. If we could collect that information, then we'd have an average number of miles in between failures of any given part.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 01-30-2003, 09:16 AM
CigarJohnny's Avatar
Exclamation transfer clutch
transfer clutches are not consumables in my book and should be seperate from the transmission. So I guess I'm saying you should add that as well to the list of choices
Old 01-30-2003, 09:20 AM
good pointe mrpockets
doesnt say how many times.. and most of it is due to wear and tear. i guess
but it should help some how atleast narrow down to the top 3 common things.
too bad we can add the miles also i.e
transmision over 100,000 miles i guess i should have put miles on there
Old 01-30-2003, 09:22 AM
Also if you edit the poll and add more choices, will we be able to add to it? The poll tells me I already voted and cannot do so again. If you add options I am unable to check them. Perhaps you should delete this poll before it gets too many replies and start a new revised one? Just a thought
Old 01-30-2003, 09:28 AM
wheres randy at whene i need him. =<
they can change the poll around.. if not some one else can start a new and better one i guess and i will delete this one
Old 01-30-2003, 12:49 PM
Invisible avatar
Smile
Also....The poll asks "what have YOU replaced"? I'm aware of a few things that were replaced by a prior owner, but during the two years I've had mine, only two of the listed items were replaced.
Should we add ALL known repairs?
Ron (trying to make things more complex).
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 01-30-2003, 12:54 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
I can edit choices on the poll, but, I don't think I can set it to allow people to vote more than once, or add to.
Randy Johnson
Mike Davis -- at Reading VI
Old 01-30-2003, 12:58 PM
Moderator
If we really wanted to track how many times each owner has replaced a given item, and how many miles are on his or her car, I would think that we'd have to make it part of each member's profile. Then we could compile the results. I don't know anything about vBulletin, so I don't know whether or not this is possible. I would think that it'd be basic database programming.
2005 Outback
END OF LINE
Old 01-30-2003, 01:01 PM
Aredubjay's Avatar
That, would be a "sith" question.
Randy Johnson
Old 01-30-2003, 01:05 PM
That's what I wuz afeared of
Sorry but all the "cousin" comments in another thread got the better of me.
Old 02-01-2003, 07:22 PM
Would sensors be consumables? (O2/knock/engine temp/crank angle/cam angle....)
