Old 06-10-2014, 02:47 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Are SVX rear axles unique in the Subie world?
All,
Question for those with in-depth knowledge of Subie axles. Are our rear axles interchangeable with those of other Subies? I know other Subies use the R160 rear diff, but something tells me the SVX's rear axles are somehow "special".
Thanks in advance for everyone's help on this.
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-10-2014, 03:02 PM
Re: Are SVX rear axles unique in the Subie world?
They're 100% unique thanks to the unique viscous LSD carrier in the diff. Hybrid axles are easy enough to make. The outer part of the axle is the same as 05+ STI i believe.
Old 06-12-2014, 04:33 PM
SVXRide's Avatar
Nate,
So, what if we went to a Cusco mechanical LSD that was designed to work with the the R160? Would, say WRX axles work? Don't all STis use the R180 rear diff?
Thanks
Bill
Old 06-12-2014, 05:30 PM
Originally Posted by SVXRide View Post
Nate,
Thanks
Bill
If that mechanical LSD is meant for a WRX, then getting appropriate year WRX inners could be used, but you would still need hybrid axles due to the hub side of the axle.
Yes, all STI's in the US use an R180, but the hub is the same as the SVX. So again, a hybrid axle, or if you're using an R180, Sti Axles will then bolt in.
The STI and SVX use the same size bearing. No other Subaru does.
Old 06-12-2014, 08:43 PM
Tapani Tapani is offline
Some of the after market diffs have double grooves for the circlips to facilitate different inner CVs.
For example the Quaife Torsen I have is one and the only thing I had to do was to cut off the small splined end which goes into the viscous SVX unit.
There's a picture of this somewhere on the forum.
Tapani
Old 06-13-2014, 01:40 PM
SVXRide's Avatar
Tapani
Tapani,
This thread? http://www.subaru-svx.net/forum/show...=Quaife+Torsen
Nate,
Think you could tackle this?
Bill
