Old 05-28-2014, 07:01 PM
alia176 alia176 is offline
Just got bunch of codes all at once!!!
Not sure what's going on but there has to be a good reason why I got a crap ton of Dx codes all at once. Car seems to be running well but obviously something is amiss here.
Code 14 #1 Injector
Code 23 Air Flow Sensor
Code 32 O2 Sensor 1 (Right)
Code 35 EGR solenoid valve
Code 37 O2 sensor 2 (left)
Almost sounds like a harness that's making intermittent contact. It's not possible for all of these items to fail at once So, let me see if the dang mice/rats chewed up anything. I did clean up a rat nests all over the engine couple of days ago so they might have gnawed on a wire here or there Freaking things are the bane of my existence.
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 05-28-2014, 08:31 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: Just got bunch of codes all at once!!!
Just answering because no one else has yet. I could be wrong but it won't hurt to check the main engine harness to the left of the tb and the maf connector off the air box.
Wanted: Steering Wheel
Old 05-29-2014, 05:44 AM
Upon a closer look at the area under the manifold, I see frayed wires on the passenger side I'm going to remove the upper intake and see what's going on down there today. Those rat bastards
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 05-29-2014, 05:30 PM
Sorry for the late reply. If all came at once I would have suggested looking at the wires. If those had checked out well, then checking for a misfire on cyl1 or loose connector, cleaning the MAF and clearing codes would be the route to take.
Hopefully patching up those wires does the trick for you.
Old 05-30-2014, 03:29 PM
The intake is off so I can now access the two frayed wires. Shouldn't be too difficult of a fix. Check out the pics.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 05-30-2014, 05:37 PM
ShiuludeSVX's Avatar
Wow. That does tell a story, I would say.
I just fired mine up again today after having the engine out. It ran for a couple of tries, but idle was jumping, so I shut down. Now it cranks, but no run.
Have to look further.
We have a similar problem in Arizona if a vehicle is not driven for more than a few weeks. Packrats will do some pretty odd things when they get near a wiring system.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
