Old 05-28-2014, 11:26 AM
kuritsa kuritsa is offline
ABS Unit
I have discovered a small leak somewhere from the abs unit. I shall be removing the unit shortly. I post here to ask if there are any o rings or seals which could possibly be the cause. It isn't causing concern yet as it's only a weep and brake performance us normal with no codes or flashing lights but I would like to know if there is a procedure for taking it apart. I have searched here but there doesn't seem to be much about it. Thanks in advance.
Old 05-30-2014, 04:42 PM
Re: ABS Unit
i rebuilt one on an outback once. it was nothing but a bunch of o-rings. they tend to leak from the little round plugs on the side of the unit. on the outback you push the plug down to access a snap ring then a spring will push it out. replace the o-ring and put it back. i would take it apart as little as possible.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
