Old 05-17-2014, 04:19 PM
MAF Replacement
So it seems my MAF starts acting up. The smell coming out from the exhaust is annoying, I am sure unburned fuel. Mileage per gallon is low.
Tried:
- Cleaning the Filter (K&N)
- Cleaning the MAF
- Re-welded the MAF board.
- Re-checked if there are any leaks in the system
- Cleaned the AIC Unit the proper way.
The car is simply not idling correctly. The rpms are bouncing from 300 to 600 or so. I am pretty sure I have a MAF problem.
It has the yellow tag with the part number:
22680 AA240 A36-601 R63 which is not common to other SVXi since my car is from the Middle East. What are my option guys besides purchasing a new one? Can other Nissan/SVXi MAFs fit my car properly?
10x
Old 05-17-2014, 08:55 PM
Tapani Tapani is offline
Re: MAF Replacement
If you decide to replace the MAF try PM:ing kissmedeadly. He's in Moscow. Most hits for your part # are in Russian... from the number of hits I would assume it's used in another Subie too - not just SVX.
Your car does not have O2 sensors, correct?
Do you have the Ecutuner or another way to look at real time data from the diagn port?
/T
Old 05-17-2014, 11:51 PM
Re: MAF Replacement
What did you to get to Russian links? I tried it from my end, gave me nothing (
Your search - 22680 AA240 A36-601 R63 - did not match any documents.
Suggestions:
Make sure that all words are spelled correctly.
Try different keywords.
Try more general keywords.
Try fewer keywords.)
EDIT: Yes, used the first 10 digits, found a Russian site. Thanks
