Old 04-05-2014, 06:11 PM
zavikan zavikan is offline
Running without charcoal canister?
I saturated my evap canister with gas. Should I run without it, or leave it attached until I get a replacement? How critical is this part to normal running?
Any way this would cause a knock sensor code (before I go replace the knock sensor)?
James
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 04-05-2014, 08:02 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Running without charcoal canister?
When the car is not running, the canister absorbs fuel vapor from the gas tank. Without it, you will smell gas fumes under the car. When the car is running, the fuel vapors with filtered air is absorbed from the canister into the intake. Without the canister, you will have unfiltered air going into the intake (dirt, dust, particles?) I would leave it on until you get a new one.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 04-06-2014, 06:34 AM
After 22 years do we really think the canister is effective??
Old 04-11-2014, 03:18 PM
The vapors are absorbed by the charcoal inside and when you start the car, the purge solenoid allows those vapors into the intake and burning off. It doesn't lose its effectiveness.
You can always just loop the vacuum hose as well and bypass it.
Old 04-12-2014, 12:52 PM
if you hook it to a vacuum source with the inlet plugged the gas will evaporate and it will be reusable. or just leave it in the sun for a couple days.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
