Old 03-19-2014, 03:21 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
power indicator
Is it normal for the power light indicator to flash a few times at start up? This never happened before. It happens occasionally. No trans error codes.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 03-20-2014, 10:20 AM
rvnmaniac rvnmaniac is offline
Formerly known as henryrace@hotma
Re: power indicator
Not normal go to How to documents for the codes
HENRY
92 SVX Claret(No More)
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 03-20-2014, 04:16 PM
Re: power indicator
If it flashes like 16 times at start up, you have a transmission problem.
First check your dropping resistor behind the battery and see if it has resistance.
If no resistance you need to replace it.
Old 03-23-2014, 07:50 PM
dannmarr's Avatar
I work for my SVX
Re: power indicator
So far it hasn't happened anymore. It happened only a few times on cold mornings. It only flashed about five times. The trans was rebuilt and drives great. I still haven't tested the resistor, but I replaced that before. Thanks for the responses.
Subaru SVX for fun
