Old 02-28-2014, 03:16 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
camber change vs. toe change results on front wheels
I am under the impression that increasing negative camber on the front tire will increase positive toe or more toe in..am I delusional or is this correct?
THX
Old 03-03-2014, 10:41 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: camber change vs. toe change results on front wheels
THX
Both are adjusted independently on an alignment rack. You can have zero toe with -3 degrees of camber (ask me how I know ). Is your question more of a "what happens with the toe in a dynamic situation?".
Cheers,
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-04-2014, 07:09 PM
bishop bishop is offline
All I know is these cars need a little more caster so the wheels track straight better.
