Old 02-21-2014, 04:48 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
New set of horns install
Had a set of twin Wolo electrics laying around and finally got inspired to install. Location : I removed the driver's side marker/signal light. In that ample space are 2 sets of 10mm bolts on the medial wall, anterior set holds headlight assembly.
Using the Wolo parts I mount them vertically off the bottom rear bolt. Since I used this area also as the ground wire attachment, needed to clean off paint under bolt to bare metal and used lock washer for solid contact. Used one of the OEM horn 12V leads to supply power( male spade connector); 2 spots to thread wire into mount area, throught the bundle or small hole just in front. I used the small hole with a rubber grommet to avoid chafing.
Plenty of room, any size set of horns should fit easily. Just takes a bit of manouvering to insert them through the upper opening and run hot wire behind sheet metal support so it isn't pinched when you put the marker light back in.
Just a pop off of the Wolo lead and reattachment to stock horn and back to original setup. Presently, much louder dual electric horn sound obviously than the "beep, beeps".
