Old 02-19-2014, 04:05 PM
Gamesy's Avatar
Gamesy Gamesy is offline
flywheel resurfacing
does anyone know for the 6spd flywheel if the mounting points for the pressure plate need to be brought down too?
shop said it would be different by 16thou
Old 02-19-2014, 04:29 PM
Re: flywheel resurfacing
If that all .016. I don't think that is going to hurt you. That's only a little
More than an RCH.
Old 02-19-2014, 05:11 PM
Tireiron Tireiron is offline
Had mine resurfaced, it's no issue. As long as the nominal thickness of the flywheel is within tolerance it will work correctly.
Old 02-19-2014, 07:58 PM
Gamesy's Avatar
does anyone have the tolerance or spec? cant find it.
Old 02-27-2014, 04:29 PM
Gamesy's Avatar
fyi, according to exedy, an sti flywheel is 14.6mm +/- 0.1mm
