Old 02-17-2014, 04:31 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Drive shaft question
My '92 had a 96 legacy trans/4.44 swap out...does this mean I have a rear driveshaft setup still from my SVX or was a Legacy shaft used ? Will either fit my car now?
Thanks,
Old 02-17-2014, 06:22 AM
Re: Drive shaft question
The 4.44 1997 Legacy Outback swap on my Claret used the SVX driveshaft. I think it's the only one that will work unless you did a manual swap. I'm not 100% sure though.
Old 02-17-2014, 07:29 AM
Correct. You're not swapping to a different sized transmission so the driveshaft remains the same.
Old 02-17-2014, 08:06 AM
Thanks,
You need an SVX driveshaft....
