Old 01-23-2014, 01:51 PM
scoobymal's Avatar
scoobymal scoobymal is offline
4 wheel steer geometry (JDM)
I'm having a few "issues" with my 92 JDM Alcyone, I will shortly be changing the front track rod ends, I will be getting the tracking checked on a 4 wheel tracking/alignment machine, does anybody know what the rear settings are? are they likely to be the same as a normal SVX that does not have rear wheel steering?
Thanks Mal
Old 01-25-2014, 04:14 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: 4 wheel steer geometry (JDM)
Check with Shane Hobson here in NZ
Old 01-25-2014, 05:48 PM
ShaneHobson ShaneHobson is offline
I don't know the answer to your question, but I may be able to dig out a wheel alignment result for my car if that helps. But I don't have any factory specifications.
Old 01-26-2014, 05:07 AM
scoobymal's Avatar
Thanks! that would be a start.
