Old 01-16-2014, 10:24 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Help with removal of Dash (not instrument cluster)
Hello all,
As the title states I need help/guidance with the removal of the dash, NOT the instrument cluster! I know how to do that and there is a How-To for it as well. Purpose: I am trying to gain access to two connections that are part of the blower motor harness. These two connections were not accessible even after I removed the glovebox/escaine and the metal frame behind it. The next step I can think of is coming from the top so I need help removing the dash. NOW if someone has a different approach for this PLEASE dont hesitate to share your thoughts.
Thanks in advance,
Sam
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 01-17-2014, 06:14 AM
Re: Help with removal of Dash (not instrument cluster)
Here is the complete dash removal procedure from the service manual. It doesn't look too bad, although I'm sure it will be a tedious process.
File Type: pdf MSA5TCD95S_27_instrument_Pannel-DASH REMOVAL.pdf (352.8 KB, 250 views)
Old 01-17-2014, 08:31 AM
Svx95's Avatar
eg33svx95
Sean thanks so much for that service manual, it helps a lot!
Sam
