Old 12-31-2013, 02:09 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Location of fuse 18 ?
remember that I have a RH Drive .... incase it makes a difference.
PS Happy New Year to all.
Old 12-31-2013, 04:00 PM
Re: Location of fuse 18 ?
Fuse no. 18 is in the fuse box under the instrument panel. Should control cruise, ABS and power steering.
It is on the bottom row In tthe very center (there are 3 rows)
4th fuse in from the left or right.
Old 12-31-2013, 06:47 PM
SURTEESS's Avatar
thanks for that - fuse is in tact - still the cruise control does not work? - is there a relay in the cruise control supply ? if so where is it located?.
thanks again.
Old 12-31-2013, 10:02 PM
92 SVX 92 SVX is offline
thanks again.
On the LHD cars there is a vac hose that goes from near the battery to the firewall, where there is the cable to the throttle body, if that vac line is old it could be leaking.
Old 01-01-2014, 09:32 AM
If the Cruise Control light in the switch comes on, but it won't engage, the vacuum hose could be disconnected or damaged.
Definitely check the cruise control vacuum hose. It connects to a small black cylindrical modulator, which is attached to the firewall , just to the left of the brake fluid reservoir. Look around in that area for a disconnected small black hose.
This is easy to accidentally disconnect (especially if you are checking tranny fluid and most definitely when you are changing the rear plugs. Just find it, plug it back onto the nipple on the right side of the modulator and all should be fine. You can zip-tie it to make it more secure
In the photo below, I put mine inside a braided s/s line. Mice had chewed a small hole in my original rubber line, so I had a vacuum leak. I replaced the
entire length of hose so it wouldn't happen again.
Old 01-01-2014, 12:09 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Also check the fuse for the horn, I don't know if that is #18. But the horn fuse is with the cruise control.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
