Old 12-16-2013, 08:02 PM
SUPER SUPER is offline
Re: oil leak on top of motor
Originally Posted by SUPER View Post
IRIS valve o ring. OK. Thought u were pulling my leg.
PM sent re o ring
Old 12-17-2013, 04:13 AM
wdb wdb is offline
dances with roads
Thanks to the more experienced folks for chiming in. I had oil pooling on top of the motor + a code for a bad knock sensor, at ~150K miles on my car. Both were cracked. I assumed their replacement was a given while the intake was off, at least on any motor with 100K+ miles. But maybe that was just my car.
And I didn't know about the IRIS O-ring at all! Oh well, maybe next SVX.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 12-18-2013, 03:04 PM
Thanks for all the knowledge and suggestions. Parts ordered. Will dig in when they arrive.
Old 12-23-2013, 07:30 PM
Got the o ring for the IRIS. Is there a diagram on the site that shows where this goes?
Old 12-23-2013, 08:12 PM
Under the intake manifold.
If you have the alternator removed you MIGHT be able to replace it while the intake manifold is still installed on the engine.
Be prepared to use words that would have your parents wash out your mouth with soap.
It is only four 12mm bolts (outside wrench diameter) and one link to deal with, but what a PITA!
Old 12-23-2013, 08:18 PM
92 SVX 92 SVX is offline
Yes, I recommend you pull the intake manifold and replace every vac line under it, as they will likely be brittle. Just be very careful with the plastic nipples they tend to break if you look at them wrong.
While the intake manifold is off the iris valve is much easier to deal with.
Old 12-23-2013, 08:59 PM
What He ^ said!
Old 12-24-2013, 09:47 PM
I think this shows where the IRIS O ring goes. Found it in a post from LetItSnow.
Old 12-25-2013, 02:53 AM
In the above picture the I.R.I.S. valve, (not the IRIS check valve) is next to the can of WD-40, sitting on the paper towels.
Oh, and IF you take off the intake manifold its a GREAT time to change the $3.00 PCV valve.
I might have said this before, but, hey, I'm old...
Old 12-26-2013, 10:37 PM
So, when u take IRIS valve out to replace o ring, do you do anything with the valve while it's out? Clean or lube?
Old 12-27-2013, 01:23 AM
Cleaning it would be nice.
As far as lubing it...
The shaft pivot points get no lube, other than engine oil vapors from "The Factory".
If it is worn to the point of noticable wear, maybe you should just replace the IRIS valve assembley,
(but it's like $300.00)
Old 12-27-2013, 06:42 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
PCV valve was a huge PITA. I think mine was overtightened, or the aluminum fused with the metal, but there was no way I was getting mine off without the manifold off and some major elbow grease. A side benefit: the SVX runs happier with less vacuum leaks after replacing the brittle/cracked hoses . Really long needlenose pliers go a long way in this project.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-27-2013, 08:33 PM
Originally Posted by dannmarr View Post
http://www.subaru-svx.net/photos/user.php?svxfiles|24710
16195AA030...Check Valve...$21.08
So I have the PVC valve, the knock sensors and the IRIS o ring. Plan to replace vacuum lines too. I did not order a check valve. Is that a likely item to fail?
Hoping to get started. Should I order the check valve too?
Old 12-27-2013, 09:21 PM
The I.R.I.S. check valve is about $25.00 or so,Subaru part #16195AA030
and can EASILY be broken.
If it has a crack in it (quite common) then it will fail.
They can be replaced without removing the intake manifold.
I use 12" long hemostats ,
a head lamp, cause my eyes are old...
lift the car seversl feet in the air, again cause I'm old...
But, HEY, while you are down there.
Old 12-27-2013, 10:39 PM
Hopefully the local dealership has one... don't want to wait for shipping.
