Old 11-19-2013, 07:54 AM
Gamesy's Avatar
Gamesy Gamesy is offline
svx rear axles ans sti r180 diff
Do the svx rear axles fit the 6spd Sti rear diff?
Old 11-19-2013, 09:48 AM
dragoontwo dragoontwo is offline
Re: svx rear axles ans sti r180 diff
No. However the STI axles fit our hubs.
'92 SVX LS Pearl White - 6mt
Old 11-19-2013, 10:05 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Nope. Have to get STi rear axles.
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-19-2013, 01:45 PM
Gamesy's Avatar
thanks guys, good thing i opted to get the axles with the transmission
Old 12-18-2013, 12:38 PM
92 SVX 92 SVX is offline
I am searching so I may find this.
SVX rear cv axles are difficult to find, are any other subaru's rear cv's going to fit
Old 12-18-2013, 05:46 PM
Tireiron Tireiron is offline
No... however if you can find an R180 from an STi with 3.54 gear ratio and get the 05-07 STi rear shafts it will work. There is a slight modification to get the diff in and you may have to swap the front flange over but it will all fit. Not necessarily the cheapest solution.
Where are you located? There may be someone local with good axles. Oh and the SVX rear axles are left and right specific also, just to complicate things a little more.
Old 12-18-2013, 06:13 PM
Thanks for the reply, I am in jax florida, if shipping charges were not so high I am fairly sure nate, or someone could grab a set, but as it is I will be looking locally there is an occasional svx parted around here.
I may just leave the cv's alone I do plan on doing a manual swap, 6spd is preferred I just talked to a auto recycler in tampa that would have trans/rear diff/all 4 axles/spindles (if I wanted them) and dccd for about 3500 shipped I will see what else I can find as well
