Old 11-18-2013, 10:57 PM
Marcus Marcus is offline
water in passanger compartment - how to fix it
Dear All,
after heavy rain I noticed the floor behind passanger & driver seat was soaking wet. I am not 100% sure (since the car was not exposed to heavy rain this far again), but I believe I found the root cause: The fancy looking door window design. The inserted metal frame does two things: It works like a rain guard and - unfortunately - creats a non linear profile (where it connects to the door body) for the seal to fit. Due to aging the seal becomes stiff and does not fit anymore (s. pictures). So I cut it at the inner (moveable window) side and filled the gap at the outer (non moving window) side with silicone.
The triangle in the lower corner has the same bending effect on the seal, so I cut it, too. This far the SVX kept dry in the inside...
Kind Regards
Marcus
Old 11-19-2013, 04:46 AM
Tapani Tapani is offline
Re: water in passanger compartment - how to fix it
Also, make sure the sunroof drains are not plugged.
/T
Old 11-19-2013, 05:24 AM
/T
My thoughts as well...
Old 11-19-2013, 07:02 AM
redlightningsvx's Avatar
Collision Refinishing Tech
The window moulding being like that have nothing to do with water inside behind you seat cause it drains out the bottom of the door to the rocker. Your sunroof tube is pointing towards the inside of the car behind the kick panel or you have a hole in your floor, one of the 2.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
