Old 10-16-2013, 02:16 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Blower Motor ALWAYS ON
Hey guys and gals,
The problem is related to the blower motor. The motor will always stay on even after I press “off” on the HVAC panel. I had never really bothered to look down there as I thought that was normal, but I just got annoyed this morning by it so I checked. Right away I noticed that It was missing a relay, which at some-point was replaced by a 30A fuse that is hardwired (I’m guessing the previous owner had issues with it).*See Picture The main goal is to actually make the blower motor to STOP spinning when I push the “off” button because I’m so sick of the background noise. So, how can I go about achieving this? Should I install a separate switch? Or Does anyone have an extra relay assembly? Also is there supposed to be a cover that hides all this stuff or is it supposed to be exposed like in the attached picture.
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
