Wipers
I need a new set of wipers but I know for sure that the ones I have on just aren't the right ones. I looked in the owner's manual and it says nothing about the type/lenght of the wipers.
Can anyone pitch in?
I got my girl, I got my glass, I got my car and I'm ready to f... |
Re: Wipers
22" for the driver and 19" for the passenger side is ringing a bell, but I'm not totally certain. A parts store should be able to look it up for you though.
Re: Wipers
22" and 20", I bought a set yesterday at Advance Auto when I was in the USA.
Re: Wipers
Driver - 22" Passenger - 20" Rear - 18" |
Re: Wipers
Ah, that's very nice info, thanks
Are ALL wipers of the same angle etc. It's a global standard, I can't go wrong as long as the inches are right?
Re: Wipers
I would also recommend a set of PIAA if you care
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Re: Wipers
I also use 19" wipers in the rear instead of 18". Only extends 1/2" more on each side of the arm and increases the wiping area.
Re: Wipers
dcb |
Re: Wipers
I still use the OEM assembly with the bumpers on them (which are still available from Subaru). The narrow universal inserts work well. Last time I ordered blades from Subaru they only lasted a couple of months. Ithink they were so old they had rotted.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
Re: Wipers
I did something similar last time I changed the front ones. The 20" one I was replacing was in better shape than the 18" one on the back, so I swapped it over. Actually increased the area that gets wiped by a good amount, especially the top section of the window. 19" would fit a bit better I think.
Re: Wipers
Info form piaa website.
SVX92-97 D.S.C1/C1 22" 550mm P.S. C1/C11 20" 500mm REAR C1 18" 450mm
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
Thread Tools | |
Display Modes | |
