Rim that fit
Found this. Could be useful
http://www.autosportz.com/article_wh...m_fits_car.htm Question : are all Subaru rims the same bolt pattern and center hole. 2003 Legacy rim fit an SVX ??.?. And to compare tire size this works great http://www.rimsntires.com/specs.jsp Last edited by Conn SVX; 10-18-2012 at 10:43 AM. Reason: Add tire comparison |
Re: Rim that fit
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Re: Rim that fit
And Tribeca
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: Rim that fit
Technically, aren't SVX's 5x114.0 and STI's 5x114.3? I seem to recall reading that here at some point.
Re: Rim that fit
I think not. You may be confusing the bolt pattern with the offset; SVX being +55 offset and STI being +53 offset.
Re: Rim that fit
I wouldn't trust that site. I have an Audi A3 2008 which uses a 5 x 112 bolt pattern. The site shows it as 5 x 100.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
Re: Rim that fit
Is there such a thing as a 114.0 pattern?
Re: Rim that fit
A quick glance around the web suggests that Hyundai and BMW have been known to use 5x114.0 and Chrysler's used 5x115.0.
You'd think that automakers wouldn't mind a little bit of convention!
Disclaimer: The above post is on the internet. |
Re: Rim that fit
Will 38 to 45 work on the SVX
SVX says 42to50 Is it that tight of dim? 42 min. And 38 is to little. Will that mean it will stick out farther or rub the suspension ? |
Re: Rim that fit
That would go for 5.x114 as well. |
Re: Rim that fit
Good to know. I never bothered to check up on that, I just recall reading it at some point on an svx site and took it heart. My gods, everything you read online isnt always correct?!?
Re: Rim that fit
Soo is the 5 114 going to work with the 5 114.3 ?
35 offset With a narrow 205 60 16 tire will it work ? Last edited by Conn SVX; 10-19-2012 at 07:52 PM. |
