#61
Re: OEM struts. Options?
-Mike O |
#62
I think part of the rear strut failure problem is the soft springs. Even with my new Koni inserts, they sure seem to be working hard with the stock springs. The front, not much activity at all.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
#63
Maybe a different approach will yield a solution. -Mike O |
#64
They are 300 inch pound QA1 springs. On the back stock SVX struts go some 250 inch/pound 12" QA1 coil overs. The Racer is down to about 2500 #s, and MUCH closer to a 50/50 weight ratio than most SVXi. Tomorrow and Sunday Radarwiz will autocross it at The Pumpkin Carve. New different size tires, different type, (radial slicks vs bias ply slicks) Almost twice the spring rate, No pressure. No pressure at all!
#65
You do want pressure. In fact around 25 psi up front 30 in the rear as she is an SVX and has more weight in front of the front axle than you would if you were having twins my friend.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
#66
I'm sure that was directed at me.
But I feel no pressure. Just as long as I'm not as bad as this guy: http://www.youtube.com/watch?v=jv4m41viy4I
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
#67
#68
Dayle at Motorsportwarehouse sells front and rear struts for $370.00 /pair http://svx-motorsport-accessories.st...et/farest.html I don't know if he keeps them in stock, but it would be interesting to see what the date codes were on the struts/ packaging. .
#69
-Mike O |
#70
Why not swing by and get us a few dates from his struts? He apparently isn't following this thread.
#71
I doubt he actually has them in stock. Someone orders from him, he gets them from his dealer, marks up the price and ships them out.
#72
This is what I am working on: http://www.subaru-svx.net/forum/show...3&postcount=39 -Mike O Last edited by injuhneer; 10-22-2012 at 03:20 PM. |
Thread Tools | |
Display Modes | |
