Old 09-05-2012, 02:04 PM
davew833 davew833 is offline
Unplugging Coils With Engine Running
I'm trying to diagnose some rough-running at idle and isolate it to one cylinder, so I'm wondering if unplugging a coil at the harness end (the colored connector) while the engine is running will give me a shock... I have not-so-fond memories of unplugging regular spark plug wires and getting a nasty surprise!
davew833@yahoo.com
Former 6-time SVX owner
Old 09-05-2012, 02:07 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Unplugging Coils With Engine Running
yes...use insulated pliers made for this purpose
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-05-2012, 02:08 PM
No it wont shock you. It only pulses gnd with a constant 12v. I would prefer unplugging injectors rather than coils... easier to get to
Old 09-05-2012, 03:48 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
You can also use an 'in line ignition spark checker' from Harbor frieght for $5.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 09-05-2012, 04:15 PM
This times a lot. The coil connectors are a pain to take apart, the injectors are cake. Plus this way you're not dumping a bunch of unburnt fuel into your exhaust.
Old 09-17-2012, 08:07 PM
alia176 alia176 is offline
How will this work when you don't have a hi tension spark plug wire like a traditional engine with a distributor?
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 09-18-2012, 09:44 AM
dannmarr's Avatar
I work for my SVX
??????????? You plug it between the coil and the spark plug. One end looks like a spark plug (plugs into the coil) and the other end looks light the coil boot (fits over the spark plug). The spark plug section of the tester is transparent so you can see the spark.
Subaru SVX for fun
Old 09-23-2012, 06:22 AM
I didn't realize there was enough room to sneak in that device since the coil pack sits directly on the valve covers. Hmm, interesting.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
