Old 09-02-2012, 05:54 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Car is low in the rear
My car sits low in the back. I realize all SVX's are like this, but it seems to be a little worse than usual. Whenever I go over big bumps at decent speed, the back end makes a LOUD thud, especially if I go over train tracks quickly. I do have a subwoofer in the trunk that is probably close to 80lbs, but there's no way that's making me bottoming out, or that I'm even bottoming out at all. Are stiffer springs the savior here? I will not even think about getting a new suspension... I can't afford that right now, and it's not necessary for daily driving. Strut mounts? It sounds almost like there's no springs there at all..
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 09-02-2012, 05:58 PM
Re: Car is low in the rear
I'm willing to bet your strut mounts have collapsed in the rear. It is a common problem as the design of them leads to debris and moisture collecting and rusting out, eventually collapsing. Even on a car that has no body rust or any other signs of rust issues.
Old 09-02-2012, 06:02 PM
steveherman steveherman is offline
When the strut mounts rust... what does that mean for the car?
Is it just replacing some parts?
Or is it lots of body work?
Old 09-02-2012, 06:12 PM
B 4 You's Avatar
#lolsvx
I know I need new strut mounts. I guess it's just time. They're fine unless I go over a really huge bump (thanks, Pennsylvania), so I'll just deal until I can find a good set. Would used ones in great condition be okay? College kid here trying to save money.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 09-02-2012, 06:13 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I had my rear spring sag to where they were touching the wheel. I replaced them and the sit like 2-4 inches above now.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-02-2012, 06:56 PM
Just the mounts themselves, not the towers like on front 3rd gen caravans.
Old 09-02-2012, 09:23 PM
Tapani Tapani is offline
See attached photos.... this came as a total surprise to me when installing the Koni inserts.... had to box the mount by tagging with 1,25mm sheet.
I now have new parts on the shelf - will swap them during the winter.
Tapani
