Old 08-04-2012, 07:25 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Crank Pulley Separated
My parents were down here in AZ visiting this last week, and they drove my SVX a couple days ago. When I came home from school, I went to move my car into the garage and noticed I had no power steering and a few of my dash lights were illuminated. I opened the hood and both accessory belts were in pieces. So I went out and bought new belts and when I went to install them today, I noticed the crank pulley started separating:
Subaruparts.com lists the crank pulley for $142.52 (part #: 12305AA141) but after some reading on this forum I found that Dayle with Motorsports Warehouse offers a one-piece crank pulley for $140 (and he is in Tucson, which I am close enough to drive to, so I could avoid shipping costs). http://svx-motorsport-accessories.st...svxlicrpu.html
Since the prices are essentially identical, it seems to me I would be better off going with the single piece pulley so as to avoid it potentially separating again. Has anyone gone this route, and if so, do you have any input?
Thanks
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 08-04-2012, 08:13 PM
92 SVX 92 SVX is offline
Re: Crank Pulley Separated
Thanks
one piece light weight pulley is the better option, but not to step on motor sport, but check ebay they usually have cheaper options, and I believe any wrx or sti and probably legacy pulley will work.
Old 08-05-2012, 07:37 AM
Darren's Avatar
Darren Darren is offline
I replaced mine from a legacy with a EJ25 engine, it's slightly heavier than stock.
I was advised by a very well respected company near me who build Subaru motorsport engines for track and rallying all EJ20, 22, 25 pulleys will fit no problem. They did however say to avoid lightweight under gear type pulleys as they wreck the pumps and alternator with the higher RPM's.
I wouldn't waste the money on a new one, you can buy 2 or 3 used ones for the price of a new one and I have heard the tracks on some of the cheaper one peice ones wreck the belts quite quickly.
If you can't get the bolt undone get a long breaker bar with the socket on the crack bolt and wedge it horizontal across the driverside (I presume yours is left hand drive) in front of the battery and very quickly flick the starter (you can isolate the ignition if you want but I've never known or had an engine start doing it), it may take 2 or 3 goes to loosen it. There is a how too somewhere on here about locking out the transmission and torque setting for tightening up the bolt after and adjusting pulleys if your not sure.
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
Old 08-05-2012, 08:29 AM
immortal_suby's Avatar
Thread Killah
If time isn't a factor head to your regional forum on nasioc.com and post up a wanted for a used pulley. You can usually get them for under $50 from someone who went with a one piece. When you get it installed just paint mark it on both sides of the dampener and you'll be able to detect any slippage.
Locker Link
2015 BRZ Limited 6MT
Old 08-05-2012, 08:25 PM
tiv0's Avatar
svxless
I'm not very sure I want to try breaking it loose with the starter idea...is there no other solution to breaking that nut loose? Obviously the crankshaft is just rotating when I turn the nut.
I'll probably run out and grab some PB blaster and a strap wrench.
Trevor
Avondale, AZ
1987 BMW 325is
Old 08-05-2012, 09:03 PM
If it has seperated, the strap wrench won't hold it.
I'd do the starter way.
Old 08-05-2012, 10:59 PM
The other way is to put a screw drive a heavy duty one or bar in the slot at the rear of the motor where out connects to the Trans to stop the crank from moving then a large breaker bar to the nut on the pulley
Old 08-05-2012, 11:14 PM
kwren's Avatar
kwren kwren is offline
The starter is the only way to go! Rest the breaker bar in a good spot and cushion the end to protect the fender area.
You can get it finished win less time than it takes to try to find a place to hold where it connects to the transmission.
A bit frightening the first time, but it is the way it is done by most dealerships.
Keith
Old 08-06-2012, 09:36 AM
tiv0's Avatar
svxless
I will be giving the starter trick a try tonight after I'm out of class.
Trevor
Avondale, AZ
1987 BMW 325is
Old 08-07-2012, 10:50 PM
tiv0's Avatar
svxless
Ok, so I'm falling behind somewhat on getting things removed, but it's kind of difficult when I work all morning and go to school all night.
I'm going to remove the radiator before I even attempt getting the pulley off. My teacher offered to let me use a puller to get the crank pulley off, so I'm curious if anyone knows what size bolts will thread into the 4 small holes in the pulley?
Trevor
Avondale, AZ
1987 BMW 325is
Old 08-07-2012, 11:09 PM
You won't need a puller, it will slide off without too much effort.
Old 08-08-2012, 05:28 AM
Darren's Avatar
You do not need to remove the radiator and as Harvey said it will come straight off or with a light tap with a hammer.
Save yourself some work and more beer time :-)
Old 08-08-2012, 11:17 AM
tiv0's Avatar
svxless
Ok great.
...and technically I've still got a little less than a month before I can enjoy beer time...but we'll just pretend no one knows that
Trevor
Avondale, AZ
1987 BMW 325is
Old 08-08-2012, 01:04 PM
The rad doesn't need to come out, but since this is your first time, it will make it much easier if you remove the fans though. It is just the 4x10mm bolts at the top (2 each fan) and the electrical connector on each.
You may want to then tape a piece of cardboard to the inside of the radiator, just incase you slip with a wrench.
Old 08-08-2012, 02:49 PM
Thumbs down Re: Crank Pulley Separated
+1 wedge the flywheel at the bottom of the bell housing and use a breaker bar... starter method is shade tree and dangerous
