Old 07-18-2012, 05:17 PM
Jay Wrix Jay Wrix is offline
Bad ABS? swollen rubber lines?
Hey all, still having brake problems.
after my car ate the right front caliper, i installed a new front calipers, new pads, new rotors, this caliper siezed after a few stop(thou this appered to be a physically deffective caliper with a siezed piston). the supplier was kind enough to work with me and give me another, with a very fast turn around. i installed this on the vehicle. the caliper was working perfect, after a little while she siezed up again and the car is un driveable.
I currently have the right front abs sensor broken, but the fuse was removed
I have been told this is caused by swollen flex lines.... mine appear solid.
My plant manager, a former mechanic told me that he thinks it is the abs, and a solnoid is stuck open.
any ideas?
DOHC boxer six, second best sound to the ears to the Ford inline 300!
Old 07-18-2012, 05:49 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Bad ABS? swollen rubber lines?
Have you changed the fluid at all?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 07-18-2012, 06:54 PM
It's not the outside that swells, it's the inside.
Old 07-18-2012, 07:21 PM
Actually I had mine collapse . When pressure was released. The hose would collapse and the caliper would not relax , pucks would not retract and pads stuck to the disk untill they wore down. Put Stainless steel lines on.
