Old 06-18-2012, 08:42 PM
Jvan Jvan is offline
need help on removal/installation of main power window switch
How do I remove and install the main power window switch on driver's door?
Old 06-18-2012, 08:52 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: need help on removal/installation of main power window switch
Remove the 2 screws near the hinge on the door, then the 2 inside the door slot, and the 1 underneath a plastic cover under the handle. After that unplug 2 wires and unscrew the unit from the door card.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-19-2012, 04:57 AM
dcarrb dcarrb is offline
Once you've removed the aforementioned screws, pull the door panel outward from the bottom to unsnap the fasteners, then lift straight up. Hardest part of the job is getting the door lock button aligned for re-installation. Use a magnetic screwdriver to hold the smallish screw that's beneath the plastic cover underneath the door handle.
dcb
Old 06-29-2012, 05:04 PM
kjoyes kjoyes is offline
be care ful not to disassemble the door lock switch because, there is alot of small parts that make it work.\ i had mine apart and i was lucky to get it together
