Old 05-28-2013, 11:37 PM
Re: Manual conversion question
Originally Posted by Ankh599 View Post
Where to begin? First off the guy takes a year to not finish. But now it starts & runs. My issues are the connectors from the trans and the wire harness from the car do not match. My speedometer, wipers do not work either. Oh and the idle is too high. If you give any advice I would greatly appreciate it.
What year model was that box from?
Sounds like a Phase 2 box.
Harvey
Old 05-29-2013, 05:32 AM
Ankh599's Avatar
Ankh599 Ankh599 is offline
I'm not sure what you mean by box???
Old 05-29-2013, 06:40 AM
I think he is referring to the ECU ?
Old 05-29-2013, 07:48 AM
Ankh599's Avatar
Not sure what the first mechanic did. But I thought the ECU remains UN hooked but you reconnect the TCU
Old 05-29-2013, 11:52 AM
bishop bishop is offline
you've got that backwards captain, the car cant run unless the ecu is connected.
Old 05-29-2013, 04:54 PM
Sorry " gearbox".
I am thinking that the Legacy gt is later that 97, and may not be a Phase 1 gearbox.
The Phase 2 has different internals, that won't run with the earlier TCU.
Old 05-29-2013, 09:17 PM
92 SVX 92 SVX is offline
If this has a manual 5spd transmission in it there should not be a phase 1 or 2
The wipers might not work if the (speed sensitive) part of them is not connected to the speed sensors, which of course would also account for the speedometer not working.
Old 05-29-2013, 09:32 PM
Thanks for that. I thought it was a auto swap.
I put that down to ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old age.
