Old 04-23-2012, 07:16 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Cleaning A/C parts
What's the best way to clean minor dirt and other impurities from A/C parts?
I have a condenser and compressor that have been on a shelf for a few years and I'm assuming a bit of dust and stuff has gotten into them. Can I just use water to flush it out and then blow it out with air? I know the system will get evacuated before it gets charged, but it seems like it should at least be clean before I put it together.
I want to get my A/C working so that if it ever stops raining and gets warm I can still be cool.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 04-23-2012, 07:53 PM
Blacky Blacky is online now
Re: Cleaning A/C parts
I would use air but definitely not water.
Old 04-23-2012, 08:17 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Use an aerosol A/C flush solvent to clean the inside of the condensor, then use compressed air to dry. Do Not flush a compressor!
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 04-23-2012, 08:24 PM
definitely apply an a/c solvent via compressed air to flush the hard lines. The muffler (low side pressure hose --> evaporator to compressor) cannot be flushed. And certain consdensors cannot be flushed, not sure if ours is one of those...so be careful. At the very least you'll have to remove the trinary switch.
Old 04-28-2012, 04:58 AM
SVX8588's Avatar
Good thing I asked. Thanks for the input guys.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 05-04-2012, 11:17 AM
torxxx torxxx is offline
Not sure if you've already cleaned them or not, but I would suggest Non-Chlorinated brake clean.
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 05-04-2012, 04:53 PM
SVX8588's Avatar
I have not yet. I'll keep that in mind.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 05-05-2012, 01:35 PM
they make ac flush solvent. it's cheap and easy to get. might as well just use the correct tool for the job. brake cleaner leaves a thin film when it evaporates, spray it on some clear glass and when it dries you will see the remains. carb cleaner is better but still not as good as the ac solvent.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
