Old 04-17-2012, 03:22 AM
Kiss Me Deadly's Avatar
Kiss Me Deadly Kiss Me Deadly is offline
Send a message via ICQ to Kiss Me Deadly
Stock tranny oil cooler location
Hi!
Its time to install tranny cooler with MOCAL thermostat (it is sub zero half year here, so ATF will heating by stock system, and cooler will start cooling only after 176F)
The main question - will cooler works good if i`ll install it between engine radiator and A/C radiator?
The cooler i want:
I dont want to cut metal, but its the only way to install it in front of A/C radiator, here the HOW-TO by friend of mine own JDM
(the article in russian, but its all clear because of pictures)
http://www.drive2.ru/cars/subaru/svx...52867440/#post
Thank you!
P.S. Maximum day temperature is 95F here
Subaru SVX LSi `95
Old 04-17-2012, 08:08 AM
Re: Stock tranny oil cooler location
it will work in that location. it is however easier to mount it in the driver fender well. there is a write up in the how to section i think. this way you only have to cut the plastic and no metal.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 04-17-2012, 09:07 AM
Yeah, i`ve reviewed that location and i think i`ll be tired of cleaning it from mud, cause, unfortunately, there are not enough sunny days here
And its easier for me install it between radiators..
How many efficiency will missing if i`ll install it there?
For example - in front A/C radiator position - efficiency will be 100%
between radiators 75-80% ?
Subaru SVX LSi `95
Old 04-17-2012, 10:26 AM
it would depend on how much (if at all) you run the ac. this would warm up the air before it flows over the tranny cooler. the restriction of air through the condenser in front of it won't make much difference as opposed to behind it because it will provide resistance to air flowing over it from behind or in front. your location should work just fine but probably be a decent amount of work.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 04-17-2012, 11:12 AM
Mine is sandwiched between the 2 radiators. SVXFiles installed it for me. I don't recall him cutting anything.
