Old 04-16-2012, 09:20 AM
stickyfinguhz stickyfinguhz is offline
defrost is making clicking noise
friday i drove my car, used the defrost and it was fine. but saturday i went and started my car, turned on the defrost and now i hear a clicking noise once every second while it is on. the defrost seems to be working fine and if i turn off my defrost and use the other controls like regular heat circulating and everything and i hear no sound. just when i press the main defrost will i hear the clicking noise and it seems to be coming right from my steering column. any ideas what this could be?
Old 04-16-2012, 09:35 AM
Re: defrost is making clicking noise
Do u hear it in the AC mode also? Does it go away if you select economy mode?
Old 04-16-2012, 09:50 AM
no it is just for that one main defrost button. if i dont turn on that button than nothing makes a sound. but as soon as i use that defrost button i hear the clicking noise. its weird it worked fine the night before
Old 04-16-2012, 11:31 AM
Tapani Tapani is offline
I would suspect the "mode motor". It's located on the LH side of the heater box and it moves the air flow control flaps. Around one hundred bucks....
See attachement.
Tapani
Old 04-16-2012, 12:44 PM
perfect thank you. ill have to look into it with someone cause i dont know anything about it and how to read that drawing
Old 04-16-2012, 09:26 PM
Down load the AC part of the FSM from here:
http://phantomotaku.com/SVX/
The mode motor should throw a code too - the instructions for pulling the codes are in manual too.
It is just a motor+plastic gearbox to move the flaps around. Close to the gas pedal.
A bit tricky to swap, but I did it - you can do it too .
Tapani
Old 04-16-2012, 09:27 PM
just look up under your dash when you hear the clicking and feel around. you will be able to feel where it is coming from and if it has an electrical connector unplug it to see if it stops. this is common on small motors like this because a tooth will get worn down on the gear and sometimes it will continuously click as it spins one gear with good teeth past a gear with bad teeth that isn't moving.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 04-18-2012, 09:15 AM
well i didnt manage to try anything of that, but i was trying buttons out and when i hit vent i heard a louder click and than the sound on defrost went away and everything seems to be working smoothly. maybe i just clicked something into place again... i dunnnno but it was noobie luck haah
