Old 04-03-2012, 08:44 AM
johnboy615 johnboy615 is offline
Air con compressor
Having searched the forum so already: can anyone confirm for sure that the air conditioning compressor from a 92/93 will not fit my 1996.
I've found one on Ebay from a 1992 and a 1993 from a breaker and would rather fit one of these than pay the £1200 Subaru want just for the part! Thanks in advance.
http://www.ebay.co.uk/itm/Subaru-SVX...item27c4c4e34d
Old 04-03-2012, 08:54 AM
Re: Air con compressor
the older compressors were made for r12 and the newer cars use r134a. you can use it in theory but is probably more trouble than finding a used compressor for your model year. the older refrigerant compressors tend to have seals that prefer different oil and sometimes the inlet/outlet are different sizes as r134a because they behave differently.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 04-03-2012, 09:53 AM
In the UK parts cars are not as plentiful. I've had and known others that have done "retrofits" or whatever you want to call them and have had no issues for 5+ years. It's not the proper way, but he should be fine.
Since he's going this route, he should be able to drain out all of the compressor oil and put R134a compatible oil in place. This should eliminate most chances of problems.
Old 04-03-2012, 10:09 AM
are the inlet and outlet ports the same between the systems? that would be the major problem but i don't know if subaru kept them the same.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 04-03-2012, 10:27 AM
They're the same at the compressor. There are some differences elsewhere though. The connection at the evaporator, for one.
Old 04-03-2012, 10:33 AM
Yep, that's the only difference.
Old 04-03-2012, 11:21 AM
They SUBARU, converted my 92 from 12 to 134. Theft had toe evac , change the fittings and refill. I had air right up to selling the car. A good 10 years.
Old 04-04-2012, 06:23 PM
Thanks to everyone for their help. Looks like someone from the UK Svx Yahoo group has one going spare which should mean no modifications will be required.
