Old 03-24-2012, 01:59 PM
David David is offline
Getting gas out of gas tank.?
I need to get my gas tank down to 1/4 tank for an indoor show. Any ideas on how to do it without driving 200 miles?
1994 model with no mods.
Old 03-24-2012, 03:26 PM
Re: Getting gas out of gas tank.?
unhook the line at the fuel filter, direct it into a tank (or another vehicle), jump the fuel pump relay with a paper clip. if you remove the relay and start the car it will help to depressurize the lines so you don't get sprayed with gas.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 03-24-2012, 04:01 PM
^This sounds better/smarter than the siphoning suggestion.
Old 03-27-2012, 05:37 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I did it once by putting the line from the fuel filter into a 2 litre bottle then turn the ignition key to the ON position. The pump runs for a few seconds then cuts off. You get about 0.2 litres of fuel in the bottle. So just cycle the ignition key 10 times then empty the bottle and repeat.
It could take a while, depending on how much fuel you want to drain.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
