Old 05-08-2012, 11:52 AM
kjoyes kjoyes is offline
Re: Full bushings replacement
Has anyone on this forum tried the red/yellow strongflex poly bushings how do they affect the cars suspenision?
what is the part # for the 2 extra if you do the 20 minute mod.
is the 15 minute mod when you use the Help! 31000?
and the 20 minute mod the self-lubercating copper bushings/ 3/8 hose and locknuts and screws?
Old 05-08-2012, 03:33 PM
i'm not sure of the part number for the 15 minute mod shims but if you email chris at strongflex he should be able to help you out. i measured the dimensions of the help discs and had him make the shims out of the red urethane, rest of my kit was yellow. cost 8-10 bucks a piece i think but did seem a lot nicer than the steering discs. i haven't installed many of the bushings yet but the ones i have installed really seemed to firm things up.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 05-15-2012, 11:52 PM
dromano's Avatar
dromano dromano is offline
Originally Posted by 92snowmachine View Post
you probably don't have to replace the bushings unless they are worn out. the poly bushings aren't necessary just a nice upgrade if you need them already. i think there are several mechanics on the site (including me) that could walk you through anything you have specific questions about.
The poly bushings on the sway bars are a total new world, I sh*t you not, just do it! You will be glad you did, turns a leaner into a roller skate!!!! Makes your tirers feel like they are made of glue......
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 05-18-2012, 04:21 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: Full bushings replacement
Waiting for Strongflex to get back to me on p/n for the 15 minute mod in 90 shore harness (yellow) - to match the rest of the set that I have. Should be approx US$10 each, any one else want a set here in NZ - to split the postage ?.
Old 05-18-2012, 04:33 PM
i got the extra bushings in red and the rest of my set in yellow. the yellow is really hard and may give you some vibrations in the cabin. i wanted yellow but strongflex recommended the red and i have been very satisfied.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 05-18-2012, 04:42 PM
dromano's Avatar
Originally Posted by jetboy View Post
Did anyone have an estimate for the time used to swap all the bushings, considering the 20 piece set I ordered? I mean garage time, not DIY time.
I replaced my 4 sway bar bushings in 2 hours using jack stands & a creeper, done by a tech with the car on the hoist should be less time.
Old 05-18-2012, 05:00 PM
those are the easy ones. the control arm bushings and other bushings that need to be pressed out are the time consumers.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 05-18-2012, 07:48 PM
The Molinator
If I installed red poly sway bar bushings about 6 years ago.. should I skip them (2 front, 2 rear).. ordering all else, but them.. .
Or get whole kit.. and replace them too?
If I haven't replaced any of the other bushings.. after 233K miles.. Do I pretty much need them all without checking them.. ?
Thanks, jim
Jim
Old 05-23-2012, 08:21 AM
picture of a bushing
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 05-23-2012, 12:28 PM
dromano's Avatar
Thanks, jim
I suggest you take out which ever bushing you decide is easiest to remove an see if it has become the texture of a marshmello, if does, you likely will want to replace all the original rubber. When I replaced my front & rear sway bar bushings the fronts were the worst, like a warm gummy bear
Old 05-23-2012, 01:59 PM
The Molinator
Talking Re: Full bushings replacement
So? .. There are fender washers on each end to hold the POLY bushing halves together in the A-Arm? .. or other metal suspension part? Normally, the rubber bushings are solid.. with inner and outer shafts fused to the rubber .. right??
Thanks, Jim
Jim
Old 05-23-2012, 07:38 PM
The Molinator
Re: Full bushings replacement :confused:
Do I want YELLOW? SPORT? Aren't these too stiff for an old fart like me? Are they meant for track setup basically?
Do I want RED? These are more normal stiffness.. right? But stiffer than OEM rubber? .. Red best for me?.. I have drop springs with Koni strut inserts already.. ? + $35 MODS!
Thanks, Jim
Jim
Old 05-23-2012, 08:24 PM
Thanks, Jim
Yellow if you want sporty, red if you want a little bit stiffer than stock.
Yellow feels pretty good. Someone commented that the red control arm bushings felt less stiff than the stock bushings, but I think the stock ones he was referring to were relatively new, not old and worn out like most.
Old 05-24-2012, 03:02 PM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
So what's better?
Buy a OEM bushings kit or a Strong Flex Red?
My car accomodates my family, there has to be a degree of comfort, I won't go yellow.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
