Maintainance and engine shape up
So...
The exterior and interior I can handle. However, the timing belt should be changed this year seeing it happened in 2007. I know the answers are to be found around the forum but I'm overloaded with a wealth of information and need short lists, sorry. * When changing the timing belt, what should I have the mechanic do at the same time? The waterpump perhaps and... ? * If I want the engine to be in tip top shape and yield the promised power, what should I consider in terms of parts change, etc? * Should something else be replaced / inspected? The AWD was repaired in december, the climate is so cold here I doubt a 96 transmission needs additional cooling? Best Regards and thanks.
I got my girl, I got my glass, I got my car and I'm ready to f... |
Re: Maintainance and engine shape up
Water pump - YES YES YES (mine siezed 2 weeks later - subaru paid for another new timing belt & labour, as they had not suggested doing it at initial time).
I just did a timing belt and water pump on my recently acquired '92 with 143K on the clock. No signs that either needed to be done. The main reason for me getting into the timing case was oil leaks-- I replaced both cam seals, intake cam plugs, oil pump (crank) seal, and resealed the oil pump to the block with new o-ring. I also replaced all the idler pulleys while in there with new ones (I went with the PCI timing belt kit that included all 4 idlers plus tensioner pulley).
I would personally recommend all of these be accomplished with a timing belt change, because you've already done (or paid for) all the labor to get in there-- best to do it once. |
Excellent, excellent. Did you by occasion compile a parts list? I'm very concerned with leaks.
1x PCI timing belt kit (includes 4 idlers and 1 tensioner pulley, from ebay) 2x Cam seals (OEM Subaru) 1x Oil Pump Seal (OEM Subaru) 2x Intake cam plugs (OEM Subaru) 1x Water Pump (OEM Subaru) 2x right angle water bypass hoses connecting to water pump (OEM Subaru) 1x Oil pump o-ring (one that fit from a generic universal kit) 1x Thermostat (OEM Subaru) 1x Thermostat gasket (OEM Subaru) Permatex ultra black silicone (to seal oil pump to block). Very Optional (but I replaced these with new OEM Subaru because I'm weird): Both rear timing covers (I'm sure yours will break upon removal of front covers) All timing cover gaskets (I think there were 4 total, one for each of the rear covers and two on the center front cover) Upper and lower radiator hoses (since coolant was drained to remove radiator for access anyway...) ABSOLUTELY POSITIVELY REQUIRED: Lots of beer. |
Wow, this is golden!
Anything else in general I should do? The car's been through all services and has fairly new spark plugs, rear bearings and rotors changed a few years ago.
Check out this list in the How-To Documents
http://www.subaru-svx.net/forum/atta...1&d=1271140259 Save it for reference. .
Hard to say - does the car have 20k miles or 200k?
Alan 1987 928 S4 (Black) SOLD! 1997 SVX LSi (Ebony) SOLD! 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! 1987 928 S4 (Black) SOLD! 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
He said it was 113,000km, or about 82,642 miles
Don't forget the gaskets that go around each bolt in the valve cover to keep the oil in.
13271AA051 Washer Rocker Cover $2.84 each. I can't remember if you need 16 or 20. It's okay to reuse the bolts. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-22-2012 at 06:45 PM. |
Thanks a bunch, svxcess!
That said, I did valve cover gaskets too, and this is definitely must-heed advice for that job. |
I only mentioned this because he was concerned with leaks and just ordering the valve cover gaskets alone would not be sufficient. I thought it was 20, but subaruparts says you only need 16. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-22-2012 at 06:46 PM. |
if you have the belt and valve covers off and are concerned about power it would be an easy time to change your cams. http://ecutune.com/svx_camshafts.htm
