Old 02-18-2012, 03:44 PM
**Ewie**'s Avatar
**Ewie** **Ewie** is offline
Aussie in enemy territory
4-EAT "Quck Change Module"
One of these appeared on TradeMe (NZ version of eBay)
http://www.trademe.co.nz/motors/car-...-449726039.htm
Anyone know if they actually do anything??
Old 02-18-2012, 04:13 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: 4-EAT "Quck Change Module"
I have had one installed on my car for over 15K miles, on a good transmission. Definitely has improved shifting, especially under harder acceleration. Inexpensive and easy to install. There are other good options available but, will cost double or more.
Gene
Gene and Ben
Old 02-18-2012, 04:51 PM
Yes Mate they really do work. I designed it back in 2007 for my 95 Aust. model.
I did not like the way the box was controlled by the TCU, it promoted a lot of slipping of the clutch/band engagement, as they tried to make the box silky smooth, and it is has been very sucessfull.
There are about 150 working in SVXs all around the world.
Cheers Harvey.
Old 02-18-2012, 08:23 PM
**Ewie**'s Avatar
Thanks Harvey, I pm'd you before reading your reply here. SURTEES is based here in Auckland and has one fitted to his car. I'll have a chat and see what he has to say.
Old 02-19-2012, 10:41 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Ewie,
after buying directly from Australia & fitting it after a few weeks (and talking to others in both AUS & USA) they had all told me to NOT FIT IT - if the auto was working correctly!!!
These things (quote from supplier in AUS) are only to aid with slipping belt type syndrome - firms up the changes by supplying higher than normal working voltage to gearbox TCU (fools the TCU).
If gearbox is working ok (as is my case) then they can potentially do more damage than good!!.
Hence will still keep mine for when I need it!!
Old 02-19-2012, 01:27 PM
kwren's Avatar
kwren kwren is offline
Originally Posted by SURTEESS View Post
Ewie,
These things (quote from supplier in AUS) are only to aid with slipping belt type syndrome...
For the easily offended folks, if you hear some tone (whatever that means)... while reading the words and it is a little too harsh for delicate ears, I will apologize before commenting...
Don't know much... actually anything... about transmissions, but a slipping belt syndrome sounds to me like damage... damage that the "Quick change module" was designed to prevent, has already happened. Put it on after the fact?
Sorry, but wouldn't that be sort of like closing the gate after the cattle get out.
Keith
Old 02-19-2012, 01:37 PM
SURTEESS's Avatar
I bought mine from Oab_au about 4 years ago, about the time that there were a lot of doggy "dropping resistors" being sort on Ebay to fix transistor slipping issues with the gearbox - check on the following for various outcomes -
http://svxworldforums.com/forum35/
Old 02-19-2012, 06:21 PM
Ewie,
Steve you have been sadly disillusioned, needless, for a long time.
You have been given uninformed inaccurate information.
As the designer of the unit this statement;
This is just complete garbage, that was promoted by certain persons that had a problem with me doing this work.
The whole intention of designing it was to prevent the slipping wear, and heat, that the "silky smooth" programing of the TCU produced. Instead, it will help to keep a transmission in good condition for a longer time.
It is pointless to say "Hence will still keep mine for when I need it!!". If you read the labeling you would see that I state, "that it should only be fitted to a gear box in good working condition".
Yes it was the 26/8/08, it is a pity you did not fit it then, you would have a more accurate idea of it's performance.
Old 02-20-2012, 01:27 AM
SURTEESS's Avatar
Thumbs up Re: 4-EAT "Quck Change Module"
Hey Harvey, not an issue for me - I have kept the unit & will one day use it (again), but since the said person has told me a load of c**p then I sincerly am sorry - but I am only going on what I was told at the time.
Old 02-20-2012, 01:33 AM
Hey Harvey, not an issue for me - I have kept the unit & will one day use it, but since the said person has told me a load of c**p then I sincerly am sorry - but I am only going on what I was told at the time.
Thats OK Mate, just wanted to straighten out the records.
