Old 02-17-2012, 07:52 PM
Clutch release bearing
We called it a throw out bearing back in the day. Neighbor just came back from his dealer with his Forester. 100,000 miles on it . When in "N" clutch out it is squealing . The dealer told him he has to Change it immediately or it will wreck his tranny. True or false ?
Old 02-17-2012, 08:46 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
Re: Clutch release bearing
If it is bad enough long enough, it will wear down the snout on the tranny case. There are repair kits to fix a worn snout, but fixing it before the snout gets worn is a better solution .
Old 02-17-2012, 08:51 PM
Hi Mr. Penguin!
Forgot a link to the kit-
http://www.smart-service.com/store-t...leeve-kit.html
Old 02-18-2012, 04:47 AM
Thanks! I told him it was not something that could not wait until he gets his clutch job done next month. They want to do it now. He just did a 100,000 mile check up.
Old 02-18-2012, 08:43 AM
Hi Mr. Penguin!
Have them replace the rear main seal and reseal the rear separator cover when they do the clutch, whether they are leaking or not. They eventually will and it is only the cost of parts when they do a clutch job, as opposed to parts/labor to get back in there somewhere down the road.
Old 02-18-2012, 05:37 PM
Thanks for the heads up. I will tell him
Old 02-18-2012, 08:21 PM
Same person different problem
He gets car back .. Subaru Forester turbo. Picks his daughter up at school after the 100,000 mile tune up. New thermostate installed . Trip of about 6 miles. Gets to school car is overheating steam and real hot almost peg the guage.
Subaru broke the radiator when they tightened the new clamp.
Question what are chances the head gasket took a hit?
Old 02-19-2012, 10:42 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Well if the dealership broke the radiator and caused the heads to go they should cover ALL the costs in damage since it was there fault. Just tell him to complain heavily.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 02-19-2012, 04:49 PM
Not sure the head gasket went yet. What are the 1st signs? I told him to watch for the telltale white steam and the smell . Look for white milk in the oil and loss of water. The dealer changed out the radiator already, for free , so the guilt has been established already.
Old 02-19-2012, 05:54 PM
White smoke out the exhaust. They should pressure test to make sure.
Seth
Past subies:
Other toys:
Old 02-19-2012, 08:26 PM
Subaru's almost NEVER mix oil/coolant. They leak coolant into the combustion chamber or leak coolant externally. Unless they are extremely borked, then it's possible to have mixing, but at that point, you really cooked the engine and your heads would be warped.
Old 02-19-2012, 08:35 PM
Do you think the one over heating from the broken radiator could have fried the head gasket. Said it got very hot.
Old 02-19-2012, 09:11 PM
If there was still water in the system, I would say not.
Old 02-20-2012, 04:31 PM
buy a block tester at autozone or go to a shop that has one. it's a colored liquid that you put in a container over the radiator cap. it will change color if it detects any combustion gases in the coolant when the engine is running. this is a pretty sure way to check as it will detect a small amount of leakage that won't show up in the form of smoke. i usually do this when i purchase a car. told many subaru owners that they had a leaking headgasket.
