Re: Anyone with rear axle experience ('94 LSi)
You're not alone. I'm having the same problem. My diff is from an 04 Outback, and my axles are not fitting. Find out from the P.O. what was swapped.
http://i840.photobucket.com/albums/z...93705d9zzz.png |
Do the sideplates (where the axles attach) have 5 bolts like this one?
Or do they have ridges like the sideplates on the front diff?
mine:
Thanks everyone,
I'll try to get that info tomorrow |
If you can see strait through it, then, with a light see how many splined sleeves there inside.
If there are three then it is a LSD. If there is a dowell in the center blocking the way, and there are only two splined sleeves, then it is not a LSD.
More proof that Tom has gotten into many a rear end.......
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Its what I live for!
It looks like the one on top with 5 bolts.
I won't know until tomorrow. The Subaru technician that was working on it is out today.
Again, thanks for the help. |
Tom, wouldn't this indicate a Non-LSD rear set up like I have in my car?
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Subaru tech still isn't in. After talking to a couple of other people, tell me if I have this correct. The transmission number suggests that it is from a '97 Outback so the rear diff should be also. I think I remember the technician saying it is a non LSD diff. Assuming it is a differential from an Outback is it standard to use a stock left SIX axle on both the left and right sides of the Outback diff?
#28
#29
So if the left stock SVX axle doesn't snap in the right side of the differential correctly, does that suggest that something is wrong with the differential?
#30
I'm having the same issue as you then. Honestly, I would just get a pair of axles from the correct model. I know people say they're all the same, but it's not hard to source some.
