Re: Exhaust rotting away...
if you want to keep the heat shields (they are there for a reason) then drill a small hole in the heat shield and thread a screw into it until the end of the screw contacts the pipe behind it. this will hold the shield still and stop the noise.
Yeah, due to the tough inspection requirements of New York, I'm definitely doing to keep the heat shields in place. I'll probably try to solve the rattling by finding where the crack in the heat shield is, and filling it with JB Weld, but if I can't find the crack, I will probably try the drilled idea that 92snowmachine proposed.
When it comes to my exhaust, I'm going to go to a local shop or two, and see what they think my best options are, now that I'm better informed and I know what I'm looking for. I just want to make sure what I do will allow me to pass inspection, and to keep driving this car as long as everyone else! I hope to go against the stigma that is against my generation and the SVX; only wanting them for the V6s and the "funky windows!" It truly is a driver's car, and despite being young and inexperienced, I know that there are a lot of things that are incredibly special about it. That's why my uncle loved it so much, and why I passed up on the Audi that my father was saving for me when the chance to own a family heirloom came up! I'll bump this thread if I have any developments, or further questions. Thanks everyone for your help thus far! |
JB weld will not hold. I had mine welded 3 times before I finally removed them .
Do not do what he did! It is illegal first or all. A Magnaflow 94007 is a much better route!
for the record I have a 92 with straight pipes to the main catalytic converter. The straight pipes had o2 sensor bungs welded in and I have NOT thrown a code or received a check engine light yet. I will be installing the magnaflow converters referenced by SVXfiles however due to the increased/obnoxious exhaust note caused by the straight pipes.
illegal? off road use only! cars my trail runner
Did not know that magnaflow exsisted.... that would have been alot simpler of a fix, the ones i seen had an odd angle for in when i checked them at the local parts store, to me it would have put the pipes in at a 45degree angle, and I didnt really see that working, I need to do more research maybe ill order one, and cut the pipes back and reweld it in
DOHC boxer six, second best sound to the ears to the Ford inline 300! |
Performance Peddlers has good prices.
This is a picture of the Magnaflow;
svxfiles, are the two infront precats?
like the clean setup, looks great
No they are Aero AR20 resonators.
And here is the rest of the system. We decided to mount the 3rd O2 sensor (OBDII) directly behind the cat to get a cleaner emissions reading and to make replacement of the sensor easier. Flows into the AeroTurbine AR25 resonator.
You can use the AR20 resonators as pre-cats in the OBDI cars.
The OBDII cars are more emissions-sensitive and require true pre-cats to keep from throwing a code. We replaced them with small Magnaflow cats on my 96. No problems since. .
#28
Is that a custom svxfiles exhaust? That is one very clean setup!
#29
very clean, what is all the way in the back(muffler?) I see another resonator?
looks better than the setup that I hand crafted, the resonators just effect the sound correct?
#30
You should see the newer ones.
Thread Tools | |
Display Modes | |
