Old 01-25-2012, 11:31 AM
Starts funny
This has happened to the 1994 I have now and the 1992 I had, so I am thinking this is common .
I go to start the car if it turns over 5 or 6 times and starts no problem like 99.9 % of the times ,but only once now and maybe 4 times with the 92 the car does not catch and the car sounds flooded . Hold it to the floor and crank it for about 10 seconds and it starts. Just like the old carb cars. Just wondering if this happens to anyone else?
Any theory on why?
Old 01-25-2012, 12:13 PM
Re: Starts funny
sounds like you have a leaking injector
Old 01-25-2012, 01:49 PM
Re: Starts funny
Did you read it has done it once in 4,000 miles and about 400 starts.!!!
Old 01-25-2012, 01:54 PM
Re: Starts funny
that's how it starts, becoming more frequent or eventually going away all together. not saying that it's surely an injector but it sounds exactly like when the bottom well plugs leak on a quadrajet, intermittently floods the car out.
Old 01-25-2012, 07:55 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: Starts funny
Conn, just get new injectors, you've got nothing to lose
1995 POLO LSI 76K MILES SOLD
Old 01-25-2012, 08:06 PM
Re: Starts funny
Now people are telling me to spend 100's of dollars. For no reason. If your car stalled once would you replace the fuel pump? I got accused of making guesses. I will wait until I have more trouble than one miss start out of 600. Normally it will start in less than 3sec..I had this happen to my 92 10 years ago when it had 30,000 miles on it.
Old 01-25-2012, 09:00 PM
I get impotent starts on some days more than others.
I start my car something like 15-20 times a day. Based on what else I know and how it's been running and how it ran when it had issues that I had corrected, I would say it is either an injector problem or my fuel pressure is erratic.
Old 01-25-2012, 10:47 PM
Re: Starts funny
I wouldn't worry too much if it doesn't seem to be hurting anything. Odd things just happen sometimes with older cars.
Old 01-26-2012, 04:56 AM
dcarrb dcarrb is offline
Re: Starts funny
My teal SVX, which it must be said has been extremely reliable but not always an enthusiastic starter, did the same thing shortly after I bought it in 2003. Seemed to happen mostly at around 32 degrees ambient temp. Crank all day, no dice. Hold the foot-feed to the floor and she'd fire right up. Replacing the coolant temperature sensor did the trick. Simple, and $20 +/- from any auto parts place. I'd try that first.
dcb
Old 01-26-2012, 10:44 AM
Re: Starts funny
i didn't say you should replace the injectors. i just said it sounded like one might be leaking, causing your intermittent rich starting.
Old 01-26-2012, 10:56 AM
processengr's Avatar
Re: Starts funny
It shouldn't hurt to run a bottle of fuel injector cleaner through it...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 01-27-2012, 08:52 AM
johnboy615 johnboy615 is offline
Re: Starts funny
dcb
Mine is EXACTLY the same. It doesn't seem to like it when the temperature is around freezing point though not always. I think I'll buy that coolant temperature sensor AND some injector cleaner!
Old 01-27-2012, 01:16 PM
Re: Starts funny
If in fact was one injector how would I know witch one to change. Short of pulling the plugs and then I don't know if they would tell the story, since it runs and idles so good. Pulling out the clutch slightly before take off I can have it idle below 500 RPM close to 300
Old 01-27-2012, 04:26 PM
Re: Starts funny
it's hard to tell which one, if any, are leaking without taking off the fuel rail or pulling all the plugs when it acts up. if you know someone with the ability to current ramp the injectors you can usually tell which one it is without taking anything apart. trying a can of injector clean is probably a better use of time/money.
Old 01-27-2012, 06:18 PM
Re: Starts funny
That acting up is like oops it don't pop in 3sec.hold to floor 5sec. Later it fires. So we are saying tow it some place and have it checked. I think I will let it ride. I can live with it for sure. After hearing problems some are having I can live with this, slight incontinence . It started up instantly after sitting in the parking lot all day at 15deg. Temp. is not an issue . I thik it is pilot error.
