Old 01-11-2012, 12:09 PM
processengr's Avatar
Question Impact gun on rear diff plug?
Hi all,
I went to change the rear differential fluid in the ebony 92 last night. Even with the 24" breaker bar, could not get filler plug out. Do I dare try an impact gun on this?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 01-11-2012, 12:31 PM
Re: Impact gun on rear diff plug?
Wow, that's harsh. Can you get the top plug? With enough time you could suck the fluid out the top one and then refill there.
Old 01-11-2012, 12:35 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
You can undo it with an impact gun, but don't use one to put it back in. I had a hell of a time getting the drain plug out of my SVX and ended up using air tools to remove it. If your gun is capable of silly torque, turn it down a bit so you don't damage the plug.
Old 01-11-2012, 12:38 PM
kwren's Avatar
kwren kwren is offline
Originally Posted by processengr View Post
Hi all,
If you have room to get a "cheater pipe" on the breaker bar you might have a better feel for what you are doing. Shouldn't take much length...
Good luck!
Keith
Old 01-11-2012, 01:16 PM
when you take it out make sure you are prepared to deal with stripped or damaged threads in case the last person threaded it wrong. sometimes a few direct blows with a big hammer will break some of the rust loose so you can take it out.
Old 01-11-2012, 06:27 PM
immortal_suby's Avatar
Thread Killah
I just hope you tried the filler plug first!
Locker Link
2015 BRZ Limited 6MT
Old 01-11-2012, 07:15 PM
Hi all,
Are you a vegitarian?
TEEHEEHEEHEEHEE, Snort!
Since the plus is made out of soft material I would never use an air gun.
A "cheater" bar is a much better choice!
