Old 01-11-2012, 10:07 AM
THE NEW GUY THE NEW GUY is offline
run out of tranny oil while driving
As the title says, my beauty ran out of transmition oil while I was driving on the HW 15 nord, in Laval, Canada this mornig at -14 degrees centigrades.
I drove for 1km without oil, then replace the broken hose and refill with new oil. Now only 1 and 2 works. It slip on 3rd and 4th. Due to the cold, I decided to go back home so I drove in 2nd gear for about 10km.
What do you think is cousing 3rd and 4th to slip?
What do you think should I test?
Old 01-11-2012, 10:17 AM
Re: run out of tranny oil while driving
if you ran it dry you probably damaged the internals because of the lack of lubrication. how much did you have to add?
Old 01-11-2012, 01:44 PM
steamer99's Avatar
steamer99 steamer99 is offline
When I ran my GMC truck low on transmission fluid it burned out the 3/4 clutch pack, and it required a rebuild I do realize that it is a different transmission but they all work about the same.
current stable, subject to change without notice:
1995 Red SVX, 4.44 & Quick Change
2014 Nissan Titan S 4X4
1992 Teal SVX parts car
