New SVX? Toyota/Subaru Collaboration
Santa brought me the Car of the Year Issue of EVO, a UK magazine
It has an article on the Toyota concept FT-86 developed in conjunction with Subaru. The last paragraph talks about the Subaru version having a turbocharged Impreza 2 litre engine with four wheel drive. Photos of the article in the gallery,, but I don't know how to get them to display in large size. Also have a pdf I made of the article but don't know where to post it. http://www.evo.co.uk/videos/viralvid...6_concept.html http://www.subaru-svx.net/photopost/...php?photo=1901 http://www.evo.co.uk/news/evonews/24...ota_coupe.html http://www.evo.co.uk/news/evospyshot...t86_coupe.html
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
Re: New SVX? Toyota/Subaru Collaboration
I am looking forward to this car... so far we've not seen hide nor hair of the Subaru version.
Although the Subaru version is rumored to be bigger, more like the 2008-current GR chassis Impreza. (which is also related directly to the 2004-2009 Legacy chassis, which did house an EZ-type H6 under the hood) It is rumored that it will also keep the front-engined, AWD layout, instead of the toyota's RWD layout with the engine behind the front axle line, out of reach for AWD front axles from the sides of the transaxle front differential. I hope they drop this stuff SOON. The rumors are years old now, and we still wait.
"What you plan, and what actually happens ain't exactly ever been similar..." ------------ 1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it. 2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan. 1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun. |
wheels are on backwards .
Great photos of the FT-86 can be found on the concept website HERE
Here is the page that talks about the Subaru version at Autoblog Rendering in STI trim. So much for the SVX. .
I wouldn't put too much faith in that rendering. Not that I have anything else to go on, but that thing looks amateur and "ricey" at best.
Personally, my realistic hope is that it splits the difference between the 2.5RS Coupe, and our beloved SVX. Based on GR impreza, and BL Legacy (the two mule vehicles that have been photographed were chopped up versions of those two cars, which closely relate to each other anyway...) The car will be smaller than the SVX but it will likely be more generous than the old GC chassis Impreza coupe. The front end structure is common between the GR and BL chassis. The BL Legacy and Outback did fit the EZ30R engine. The EZ36 is the same outward size, and it should fit, as well, being barely longer than an EJ H4. So there is a chance that the coupe could offer H6 power, not just H4 or Turbo. With a unique body shell on the outside of the chassis, that looks better than the current Impreza, with a sleeker SVX-like roofline, and perhaps even as wide a stance as the WRX STI, with more graceful lines rather than chunky flares, it could still be a nice, AWD coupe, even if not as big as the original SVX. It probably would weigh roughly 300lbs less, as well, if the Impreza is an indication. Couple that with some interior design elements brought in from the BL Legacy, and maybe even the Tribeca, and some proper suspension tuning for a competent but not teeth-rattling ride quality, and the addition of some things like variable power steering, and things that SVX had previously... I still contend that it should have four models. -Base H4 with 5MT or CVT gearboxes, AWD standard, base interior trim, ~$22-23K, just above base Toyota RWD version at about ~20K -RS (WRX Equivalent) with 268hp Turbo 4, 6MT or upgraded automatic. sport cloth interior trim. ~$28K. -RS STI upgraded from RS with 304+hp turbo, STI grade 6MT/DCCD, sport cloth/alcantara interior with recaros, Bilstein suspension, Brembo brakes, and BBS wheels. This would be the "Track" model. ~$32K ~$3K Limited option available for those three models, with leather/alcantara, sunroof/glass roof, ACC, HID headlights, NAV system, tech package, etc. -SVX Grand Touring model. EZ36 H6 engine with 300+ horsepower, with STI grade 6MT/DCCD or upgraded sport shift automatic. Bilsteins with touring spring rates and anti-roll bars, Brembos, and BBS CH style wheels. Sport/Touring interior. Much like STI+Limited package as standard. ~$35K IF there is a business case, possibly a base SVX "L" model with the H6, automatic gearbox, and base interior, minus all the STI and Limited package toys, for ~$27K or so. Take it right into the teeth of the non-AWD Genesis coupe, and undercut the G37x-Sport and Audi A5 Quattro 6MT S-Line.
I think the car is looking amezing. But it wont bee a Svx i think it missing the windows and the dont forget the Flatsix engine.
But i really looking to see this car in action. I think it will rock..
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
Yer, Subaru version is definitely not for public viewing yet.
Rumour has it that delays to date have been caused by getting direct injection fitted to engine Friend who lives in Japan was at Tokyo Motor Show, and was indeed impressed with the Toyota coupe (he's Audi fan) but the car was run on the stand (no access to under the bonnet was allowed, period) and definitely did not sound like a boxer - and that the designated engine was tested at the N'ring in a Impresa Sti car, which does indicate the engine was not ready. The Subie version is also to be AWD, wider and longer than Toyota version. Small article from Japan mag dated 30 Dec |
I just wait till Subaru offically releases info about there verson. Im very Kean to get one for a daily run about The only pic showing the engine for the Toyota verson is sadly in the Gran Turismo 5 Game. Look at 2nd pic in this link to view... http://www.ft-86.com/media/1-grand-t...t-86-clip.html
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired 1989 Vortex 6 Maroon 1983 RX Silver Grey 1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration |
