Old 12-16-2009, 08:00 PM
subaruster's Avatar
subaruster subaruster is offline
Send a message via AIM to subaruster
fuel light
I have a 96 SVX Lsi, 70K.
Fuel was running low on fuel on the Florida Turnpike. Stopped off, got gas. The needle started to climb to full, as it did the low fuel light remained illuminated.
As of now, I have driven it for about 150 miles with multiple starts and shutoffs in-between, low light is still on!!!
Anyone had this?
Seems like the low light sensor might be stuck.
Also while driving on the Turnpike, out of nowhere comes a vibration coming from the front of the car not affecting the steering at all. Only happens while speeding up or coasting. I have searched this problem and nothing too specific comes up.
Thanks for the help,
Joseph P
Old 12-16-2009, 08:03 PM
Re: fuel light
there are two separate senders for the gauge and the low level switch. The low level switch is likely stuck down. You could learn to love it until it dislodges itself or remove the sender and move it yourself
Old 12-16-2009, 11:48 PM
Re: fuel light
The problem reported would indicate a faulty sensor or or shorted associated circuitry. Alternatively some debris may be fouling the sensor.
The low level sensor is quite a sophisticated affair, is completely solid state and does not involve a switch or contacts. A thermistor (heat dependent resistor) is normally immersed in fuel and becomes intermittently dry when the level is low. The thermistor is simply connected in series with the indicator lamp and the wiring diagram shows that no amplifying or latching circuitry is involved.
When immersed the resistance is at maximum and the lamp connected in series is not illuminated. A switching type thermistor will be used, such that there is a near specific cut off point rather than a gradual change in resistance.
It must be presumed that the thermistor incorporated has a positive temperature coefficient, so that when the level is low and fuel evaporates from off the device, the temperature drops and the lamp illuminates. This would result in a flashing effect as the level drops and car movement causes turbulence. However if and when the tank becomes absolutely empty and remains so, the lamp will not remain illuminated.
Old 12-17-2009, 04:31 PM
Re: fuel light
I never knew it was a thermo resistor... Always figured it operated on a float switch... Learn something new every day
Old 12-19-2009, 01:10 PM
subaruster's Avatar
Re: fuel light
Ok thanks,I'll try and take out the sending unit and clean the one installed first before replacing. I'll let you know how it goes.
Joseph P
Old 12-19-2009, 03:10 PM
Re: fuel light
Joseph P
Kia ora Joseph,
The sensor can easily be tested.
Connect a small 12 volt, 3 watt lamp, in order to to simulate the dash indicator, in series with the sensor and a 12 volt supply. Then immerse the sensor in fuel, at which point the lamp should extinguish, to again illuminate when the sensor is removed and in free air.
Compliments of the season, Trevor.
Old 12-20-2009, 08:23 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: fuel light
Wecome Joseph P. Not related to this thread but, if you ever need any help with other problems, let me know. I try to keep spare parts around like MAF, sensors, etc.
Gene
Gene and Ben
Old 12-22-2009, 05:53 PM
subaruster's Avatar
Re: fuel light
I have time tomorrow to do that test, Trevor. I lost my FSMs. Do I access the sending unit through the back seat or the trunk?
Kia ora Joseph,
1996 SVX Barcelona Red
2014 Subaru XV Crosstrek Hybird Touring
2015 Nissan Leaf
Old 12-22-2009, 06:19 PM
subaruster's Avatar
Re: fuel light
Thanks, I do have one question and one needed part. I am starting a new thread for the question. titled "Vibration"
The part I need, I have been searching for over a year. Remote Transmitter.
Part #: SOA386R205. It has been discontinued from Subaru. Do you have it??
Gene
2015 Nissan Leaf
Old 12-23-2009, 02:32 PM
bwb3's Avatar
Re: fuel light
I have an extra remote unit for the door locks with a broken case (the corners where the screws holding the 2 halves together). Worked otherwise. You can PM me if interested.
Gene
Gene and Ben
Old 12-30-2009, 10:08 AM
subaruster's Avatar
Re: fuel light
It seems the problem fixed itself. After filling the tank three times the light went out after the 3rd fill up!
2015 Nissan Leaf
Old 12-30-2009, 03:37 PM
Re: fuel light
I pointed out --- The problem reported would indicate a faulty sensor or or shorted associated circuitry. Alternatively some debris may be fouling the sensor.
This would now appear to be what was in fact the cause of the problem.
Old 12-30-2009, 03:45 PM
alltrac alltrac is offline
Re: fuel light
Correct part number is SOA386R317
Victor
Old 12-30-2009, 07:27 PM
subaruster's Avatar
Re: fuel light
My box's part number is the one I posted. Here is the thread I posted with a picture of the transmitter:
http://www.subaru-svx.net/forum/showthread.php?t=52655
2015 Nissan Leaf
Old 12-30-2009, 09:38 PM
Re: fuel light
That picture is the alarm module and not the remote transmitter.
Victor
