Old 11-30-2009, 11:31 AM
Jonnycash's Avatar
Jonnycash Jonnycash is offline
She was fast
I have had my svx for almost a year now. Since I got it, it has been in 3rd gear (limp home mode). I have been trying to figure out the problem and finally found a disconnected plug. I now know what its like to drive a svx... I could always tell it had potential. So 2 days later I decided to go out cruising with my buddy (he's got a fast little car thats not an svx). We were tearing up the streets and I starting hearing a ticking noise... the tick turned into a knock and now I will be swapping the motor tomorow. Prepping everything today, getting the old one ready to come out and I will back on the road on wed. I'll let you know how I make out.
Old 11-30-2009, 05:18 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Re: She was fast
Huh? Does the engine no longer run? Are you sure it's just not a coil pack?
1994 subaru svx le 112k
Old 11-30-2009, 07:49 PM
Jonnycash's Avatar
Re: She was fast
It will still run. It knocks real bad though. Don't think its a coil pack... when I turn it over by hand I can hear the noise and it will lock up sometimes. When it locks up, I can turn it back and forth a couple times and it will get past that point. I have the old motor out. Just need to swap my new timing belt and tensioner to the new one and she will be back in tomorow afternoon. I decided to change the leaky rack and pinion while the motor was out... no sense in putting that off any longer. Can't wait to be back on the road.
Old 11-30-2009, 08:09 PM
Re: She was fast
Picard?
Old 11-30-2009, 08:32 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: She was fast
Originally Posted by TomsSVX View Post
Picard?
Request... grahhnted.
Old 12-02-2009, 11:48 AM
Jonnycash's Avatar
Re: She was fast
Back on the road. Got it all buttoned up last night and took her for a ride this morning. Turned out to be a loosened tourque converter bolt that wedged itself in the bell housing (thank you aamco transmissions) Put the old motor back in... now time to freshen up the new one and drop it in maybe next week sometime. This is my first svx and the first major repair ive done to it, and I have to say that it is a pleasure to work on. Bolts come right out... everything is fairly accessable. Love this car!
Old 12-02-2009, 12:01 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Re: She was fast
Picard?
At least its not as bad as a story about racing Cobalt's
+1
Old 12-02-2009, 01:01 PM
NeedForSpeed NeedForSpeed is offline
Re: She was fast
That was an interesting problem. I've swapped SVX trans a dozen times, always wondered what would happen if some moron dropped a TQ bolt , now I know.
Good luck with the SVX
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 12-03-2009, 07:48 PM
Hondasucks's Avatar
Subaru Technician
Re: She was fast
You got lucky, I got my SVX for cheap cuz the shop that replaced the flex plate didn't quite get the torque converter fully seated into the hydraulic pump, it was seated enough to turn the pump, but off enough that it put enough load on the pump to sieze it in the housing. Good tip when mating an engine to an automatic trans, it should slide all the way home and not require being cinched down with the bolts, and there should be a slight amount of clearance between the flex plate and the flats in the converter for the bolts.
1986 VW Jetta
