Old 08-05-2002, 11:29 AM
svx_commuter's Avatar
I got a used ENGINE.
I got a used engine with 82k miles delivered to the garage I was using. http://www.subaru-svx.net/photos/fil...muter/3853.JPG
The engine was very dirty and did not look like it was stored indoors.
Does anybody know who used to own this? It was a 1992. VIN >>http://www.subaru-svx.net/photos/fil...muter/3854.JPG
I would really appreciate it if someone with CAR FAX could send me the report.
The engine I took out had several leaking valves so figured I had better check out this engine. i was not going to put it in with bad valve and rings and head gasket, even with a six month warrantee. After I cleaned off the engine I did an air test on each cyclinder for leaks in the valves, head and rings. Dropped oil in each cyclinder to help lubricate and free up the rings. The engine had been sitting around for 2 years. http://www.subaru-svx.net/photos/fil...muter/3855.JPG
I was also concerned about coolant leaks so I sealed off the coolant system with hoses and filled the engine with water at 15 psi pressure overnight. Everything was dry in the morning and that was very good. No water in the oil sump or cyclinders. http://www.subaru-svx.net/photos/fil...muter/3856.JPG
I knew the engine was sitting outside a long time, so I blew out the fuel lines on the engine. The regulator valve worked fine at 38 psi. It blew out some old fuel and water. http://www.subaru-svx.net/photos/fil...muter/3857.JPG
The engine ran on Sunday night. After letting it warm-up and giving the sticky lifters time to work free I took it for a short trip and checked for leaks. The tranny fluid was leaking from the hoses near the back engine. http://www.subaru-svx.net/photos/fil...muter/3858.JPG
Just as a reminder, this is how hard my car hit the ground. Take a look at these tail pipes. The heat shield is completly flat against the exhaust pipe. http://www.subaru-svx.net/photos/fil...muter/3859.JPG
And a from a different angle.
http://www.subaru-svx.net/photos/fil...muter/3860.JPG
I am very happy with the way this turned out at the moment. The used engine is running fine and sounds very good.
Old 08-05-2002, 01:14 PM
Lowered SVX
what exactly happened to you?
i have a used engine too. dropped in relatively easy and the car is running good. i hope everything continues to work out for you.
"Too much fun to drive!"
Old 08-05-2002, 02:24 PM
Kamaleon
vin#: JF1CX3535NH105337 INFO
I ran your vin on Carfax and this is the outcome:
05/18/1999 81,793 New York
Motor Vehicle Dept.
Hicksville, NY
SALVAGE TITLE/CERTIFICATE ISSUED
Everything else seems ok.. It doenst say the description of why was it salvaged.
Old 08-05-2002, 03:06 PM
wawazat??'s Avatar
Yeah, I'm still around
That's great news John!
Glad to hear you're back on the road again. Not that bad of a job, eh? I think we're now part of a very small group of folks here on the board who have seen the internals of our cars heart. As you said to me earlier, a job done well is a very good feeling!
What are you going to do with your original engine? I need some parts (valve covers , both sides, cam pulley (left side), cam angle sensor and mount). Are you willing to sell me some parts?
Thanks,
Todd
Down to none
Old 08-05-2002, 06:39 PM
MoreIBNR MoreIBNR is offline
Original Owner 1992-2008
Send a message via AIM to MoreIBNR
John - You should have called me - I was free on Saturday and could have given you a hand. I tried to call you but didn't get an answer.
Glad to hear it all worked out. Is that the engine from down near Phila.?
Old 08-05-2002, 07:03 PM
Re: vin#: JF1CX3535NH105337 INFO
Motor Vehicle Dept.
Hicksville, NY
Thank you much That is pretty close to what he said.
Old 08-05-2002, 07:06 PM
Re: That's great news John!
Thanks,
Todd
Hi Todd,
I may rebuild the engine, so for now no parts. Sorry. This may change if I can't slavage the head and cam from the right side. It's a little wiped in the journal. That was the side with the head leak.
Old 08-05-2002, 07:10 PM
Hi Gary,
This was used engine with a six month warrantee for about $1K as opposed to an engine with ???? miles, $3k and no warrantee.
Saturday turned out to be a family day. My son was helpping me so I didn't bother to call you.
Thank you for your help. Your tools are much more organized.
John
Old 08-05-2002, 07:35 PM
They are only more organized because they came in that box. If not for that, they would all be in a brown paper bag ;-p
Actually, I would probably buy some empty metal socket boxes and such at the tool outlet store or flea market. But the Sears box is convenient.
Let me know how the used engine works out - $1000 is such a deal.
Originally posted by svx_commuter
Hi Gary,
John
Old 08-06-2002, 05:50 AM
The price and warrantee was good. However, I was not real happy with the appearance of engine. I put on my new water pump and changed over all the idlers and T-belt. The old ones were rusty. I was told it was stored in doors but it was outside and rained on for some time. I called back and said I was not happy as the engine was not like he said. They gave me a $200 credit.
Old 08-06-2002, 05:56 AM
Where did you get it from?
Old 08-06-2002, 06:56 AM
Todd,
When I took out the head bolts each one of them cracked a few times, a lot of torque, and then as they got easier to turn, each one let out a hissing noise. Sounded as though some pressure was being released from in the threaded hole. Did you heard anything similar?
John
Old 08-06-2002, 09:51 AM
wawazat??'s Avatar
Felt and heard the same sounds John
Very difficult to break free as well.
Todd
Down to none
Old 08-06-2002, 03:23 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
svx_commuter
Hi John, I tried to reply to your PM but it said that your mailbox was full.
Old 08-06-2002, 07:18 PM
Thanks
I'll fix it now.
